How much HP
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: How much HP
    Posted: 21 May 2020 at 9:17pm
How much horsepower can a WD45 read end and transmission hold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 6:53am
More if you run light, go fast and let the wheels spin. Less if you run heavy and use grampa gear with no slippage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 7:12am
Tire size, lug profile, wheel speed, engine RPM's and weight are the factors. I know of some that make 100 HP @ 1400 to 1800 RPM and pull up to 5,000 lbs with 15.5 x 38's and never have any problems. When you say "rear end" that includes the transmission, which a WD45 trans can tolerate more than an old WD with the straight gearshift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 2:16pm
I guess the reason I’m asking is that I was thinking about doing a 292 Chevy swap. Was just curious on how many issues I was going to have with the rearend ad transmission holding up to the power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 4:03pm
I know of a modified that is a WD that had a 350 with an automatic and something like 23.1X26 tires that runs 4500 to about 6000. It runs fast and spins and hasn't had any problems. Sometimes more HP and spinning is not as much strain and just enough HP and tied to the ground.
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 5:25pm
Same ring and pinion was used in early 190's until they started to break....have late D-19 in my WD-45 but no 100 horse....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 5:26pm
That was the diesel version in the WD-45
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 10:54pm
Final drives are the weakest link.         MACK
This page was generated in 0.095 seconds.
