Harbor Freight jackstands |
Page 12> |
ford8nwd
Topic: Harbor Freight jackstandsPosted: 20 May 2020 at 10:03am |
They are recalling 1.7 million jackstands which in some cases are collapsing! Beware!!!!
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25326 |
Posted: 20 May 2020 at 10:21am |
how in the world can you screw up a jack stand?
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4768 |
Posted: 20 May 2020 at 10:35am |
A little to much virus in the steel.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 20 May 2020 at 10:37am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12250 |
Posted: 20 May 2020 at 10:46am |
It ain't easy Mr. Bergen!!! |
chaskaduo
Posted: 20 May 2020 at 11:20am |
Have 8 to 12 year olds building em without quality control.
Walker
Posted: 20 May 2020 at 1:26pm |
You use sick chickens to pay convicts and kids with. Ya gotta expect retaliation.
chaskaduo
Posted: 20 May 2020 at 1:31pm |
Walker, or sick Bats.
Walker
Posted: 20 May 2020 at 1:40pm |
At this point using bats as pay may be covered in their morals clause and forbidden. Or not.
Edited by Walker - 20 May 2020 at 1:44pm |
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 20 May 2020 at 1:46pm |
Mine are HF but not made anything like the pictured ones.----HHHHHMMMMMMMM! ---oh well!
chaskaduo
Posted: 20 May 2020 at 2:15pm |
Are they older than the recall dates or even the same model #'s ?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88595 |
Posted: 20 May 2020 at 8:31pm |
there is a potential, while under load and with a shift in weight, for the pawl to disengage from the extension lifting post, allowing the stand to drop suddenly.
Dont see how the "pawl" is going to disengage. Weight of the truck is DOWN and locking into position.. You have to raise the foot up an inch to get the pawl out of the lock... UNLESS you dont have it engaged properly to start with ? .... or old and rusted up ?
ocharry
Posted: 20 May 2020 at 10:56pm |
Yeah I got a set too...just used them and I dont get it either...they say paw doesn't engage ratchet deep enough
When I took the utv off them this afternoon I fiddled and jiggled and banged ....I could not make them fall.....I dont know...mine are the 3 ton ones....I use these little guys all the time....I really like the size..I have several sets but these are great for ATV stuff Guess I will take them back and see what they have to say...I dang sure dont want my money back....I want jack stands...that's why I got them Ocharry |
Walker
Thanks(1)
Posted: 21 May 2020 at 1:21am |
Evidently the virus wasn't fast and thorough enough to suit em. Now they've added killer jack stands.
Edited by Walker - 21 May 2020 at 1:23am |
chaskaduo
Posted: 21 May 2020 at 7:56am |
I suspect a lot of it is operator error, like not checking that the pawl is all the way into the catch cog and not just on the tip lip of the cog. And who in their right mind would work under a movable tippy jacked up anything. I have the 3 and 6 ton ones and use em all the time. I still use extra jacks and blocks in case. I seen a Shortbed Chevy come crashing down off of a garage lift once when the guy had most of the weight basically hanging off the front of the rack. Talk about loud, and thank God the control valve was 10 feet away and nobody standing there gawking.
steve(ill)
Posted: 21 May 2020 at 8:34am |
Mine are probably 15 years old so bought WAY BEFORE the 2013 date... but they like real similar to the photos.... I bought the 6 ton units and added a 6 inch base to the bottom to get EXTRA height for working on the 4 x 4 trucks... anything you could purchase back then was way to short on the height.
but, maybe thats the problem... jacks are not tall enough and they have the arm extended all the way UP so there is not much engagement with the stand ? When the arm is fully UP, it does get a little wobbly ... Kind of like taking a 20 ft extension ladder and extending it to 21 ft ?? Edited by steve(ill) - 21 May 2020 at 8:37am |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 21 May 2020 at 9:01am |
Maybe I should start a new thread but this is related- Anyone know of a good instructional video about jacking up a tractor and placing the jack stands? Many times the best place to lift from is also where you want to place the jack stands. Evaluate what I did the last time I jacked up My Ford 3000 to swap rims-wheel hubs in order change the tread width: I used the large floor jack at the rear draw bar hanger right on center line of tractor. Got the entire rear axle jacked up so both tires were about 3" off the floor. This is a side-side tipsy condition, 4" wide floor jack pad, front axle on a pivot pin...but with wheels still on it could only fall 3". Never do this and then take off the wheels without jack stands also!! Then I placed the 12 ton HF floor jacks on each side, under axle. The stands are dished in as if made to nestle to a round truck rear diff. axle But the Ford axle casting is square and too large to nestle in the stand. It looked like a slippery situation. So I added plywood shims to the stands. Lowered the floor jack. Looking good. But then I realized the base of the HF 12ton jack stands were too close to the tire sidewall, and since i was narrowing up the tread, they would interfere. Raised the tractor again, moved the jack stands inboard and all was good. Removed wheels, broke down, reassembled to desired tread, re-mounted wheels. Comments please. |
steve(ill)
Posted: 21 May 2020 at 9:20am |
I normally put the floor jack off center and jack up ONE SIDE at a time to work on. You can normally find a spot to jack ( drawbar) and a place to put the STAND ( axle housing or drawbar anchor point) ........... very seldom would i have both sides off at the same time.
i also have a dozen 6 x 6 wood blocks about 15 inches long. I can stack 2 x 2 x 2 like lincoln logs to build up a base if you need to go over 18 inches high . Edited by steve(ill) - 21 May 2020 at 9:23am |
Tbone95
Posted: 21 May 2020 at 10:04am |
I suppose a video could be made that would provide a lot of practical tips, safety precautions, considerations. . . . seems it would be difficult to provide specific help due to all of the different tractors and what exact task you're jacking it up for. Jacking up a B and a 7080 are 2 different ballgames!
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3069 |
Posted: 21 May 2020 at 10:41am |
Have my D 15 jacked up now . I used my 3 ton Powerbuilt jack/jackstand under the PTO housing . Have a short piece of 4x4 on top of the jack under the sway bar bracket . Jacked up a little off center so the left side's up . Also have it cribbed up with some lam beam . Thanks !!
chaskaduo
Posted: 21 May 2020 at 11:10am |
I've bought some of them used Menards Railway Ties they always sell every year. Cut them up in various sizes for cribbing. They can be heavy though, but the price is right, and stumps aren't squared.
Walker
Posted: 21 May 2020 at 12:50pm |
I wound up with a pair of unnamed Chinlees I'm afraid of just by looking at them but like the guy said they work for atv's.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163 |
Posted: 21 May 2020 at 7:41pm |
Harbor Fright = The best Chinese crap money can buy
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54425 |
Posted: 21 May 2020 at 9:23pm |
Have to check mine, but last weekend, I had the new mower up on the old front end jack, to check/adjust track tension, forgot to chock the front wheels, lowered the mower, slowly onto the JS's, machine moved forward offa the FE jack, and slid onto the JS's, no damage to me, machine of the JS's. sh!t happens, be careful...
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8735 |
Posted: 21 May 2020 at 10:01pm |
My guess is operator error. Pretty soon companies are going to have to send a babysitter out with every product they sell. darrel
iowallis
Joined: 04 Jun 2017 Location: North Iowa Points: 376 |
Posted: 21 May 2020 at 10:08pm |
Went and checked mine after work, yep, I have the recalled ones. I agree with the other opinions, I don't know how they could fail but obviously they do in some situations so I will return them and maybe go to my local Sears Hometown Store and get some that match what I already have which I bought from the "real" Sears store before they closed. |
Gordy
Posted: 22 May 2020 at 9:53am |
I have some that look like the recalled ones but they different numbers than the list.
“If you can't explain it simply, you don't understand it well enough”
chaskaduo
Posted: 22 May 2020 at 10:05am |
Are they from HF Gordy?
iowallis
Posted: 22 May 2020 at 7:50pm |
Took them back today. First walked in and found a manager type guy as the checkout was backed up 3 deep. He said "bring 'em in and go to the checkout (while observing they were 3 deep waiting) and you will get a gift card". Went out and got them and grabbed some other stuff I needed and got up to the checkout and told the lady I had a set of recalled jack stands. She then asked for the recept. I told her I had no receipt but had the paper with the recall notice and part numbers. She asked for my phone number and tried to find the recept that way. Can't find it. As this was happening another worker finally comes up to open the other cash register (now with 6 people waiting) and explained to my cashier what she needs to do. She was going to set them on the floor but decided to put them in a cart "in case they get more". No prominent signs/notices anywheres in the store about the recall that I could see, plus they should have a record of my purchase tied to my email that they should have sent a notice instead of me finding out on this forum.
Gordy
Posted: 23 May 2020 at 10:21am |
Yes I am sure they are maybe older than the recalled ones but look the same grey color both 3 and 6 ton the numbers on them are 69596 and 69597
Page 12> |
