Dual 3100 loader on 7010
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Topic: Dual 3100 loader on 7010
    Posted: 16 May 2020 at 11:26pm
Found a Dual 3100 loader for a couple hundred bucks, it looks to be in pretty good shape. I'll have to make my own mounts and I'm just curious if anyone has one of these mounted to any of the 7000 series. I'm thinking about putting it on my 7010 for a spare loader tractor. Thanks Fella's!
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 1:23pm
I have one on a 200 and just plug into the rear remotes. It works pretty good. When I had to make brackets, it came off of a 70 series case, I was able to get 100 series frame rails and I cut the quick tach portion from the case brackets and welded them to the 100 series frames and then bolted to the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 1:32pm
Ice heard the frame rails may flex on a 7000, is this an issue on a 7010 too?
Edited by DougG - 18 May 2020 at 4:19am
