8000 Issues (Dr Allis)
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 8000 Issues (Dr Allis)
    Posted: 16 May 2020 at 11:06pm
The temp gauge needle went straight up and will not come down. I put on a new sending unit and still, it is at high noon. I also lost the rear work lights. Where is a good place to start checking for trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 1:05am
If the fuel gauge works, I'd guess it is the temp gauge itself. Would have to test wiring on the backside of the gauge to verify. Lights could be fuse or breaker depending on tractors age. Use Owners manual to see which style it has.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 9:33am
I'm no help for the temp gauge. Have you replaced the light switch? not sure if that would be your problem tho,,,
I had some kind lighting issues with my 8010, there is an updated light switch/turn signal..
other than that,, well,, get a test light and start looking...corroded, dirty connecters can cause problems,  burned out bulbs??
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 10:21am
Look behind the dash for pinched or melted wires causing a short
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 12:47pm
Thank you all. I HATE when the lights don't work.
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 8:04pm
If you unplug the temp sensor the gauge should peg one way then if you ground the wire it should peg the other way. Way to see if your gauge and wiring is ok. But if get nothing then have to figure out wire or gauge
This page was generated in 0.383 seconds.
