20 up Kolher oil in air filter
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 20 up Kolher oil in air filter
    Posted: 15 May 2020 at 1:35pm
Gal pal has a Toro zero turn getting oil in the air filter , its got a 20 go Kolher about seven years old- any suggestions
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 1:54pm
Engine compression low---engine in need of rebuild is usually the cause. --- There can be other causes too such as plugged crankcase vent. check that first then do compression test!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 2:05pm
Will do, thanks was running great before today stated sputtering black smoke,,
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 7:19pm
Sounds like extreme blow-by
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 8:34pm
Make sure crankcase is not over filled.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 6:39am
did you yank the dipstick out for a look see?  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 8:05am
Gonna do that after while I was gone out of town when this all happened
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 8:07am
Could be a bad fuel pump. Had one go south on my 782 CC, pushes fuel/oil out of the crankcase right into the air-filter. Smoked something awful!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 1:27pm
Turns out it wasnt as bad as said on the phone - the bolt holding the manual choke cable worked loose and it was choking the engine when it didnt need too- a good overall tune up , air filter-oil change and filter-plugs and good to go again- thanks for all replies
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 9:06am
Way to go there hero.
BY the way did you get paid well?  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 10:44am
OH YEAH,,  shes very good on that and very giving!!
Edited by DougG - 17 May 2020 at 10:49am
