Machinist question |
| Author | ||||
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: Machinist questionPosted: 14 May 2020 at 7:35pm |
Just some random thoughts rolling around. I was thinking of making a couple wooden bushings then I got to wondering if a person can machine parts from composite deck boards? I’m gonna try next time we use some at work. Just to experiment. Would be much more weather resistant than wood.
| Sponsored Links | ||||
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Posted: 14 May 2020 at 7:54pm |
My thought is it would be gummy and heat from friction would cause it it to fail as a bearing. Wood brgs were soaked in oil and certain type of wood. Anything can be machined if not a liquid, some materials are tougher
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2696 |
Posted: 14 May 2020 at 8:05pm |
I have an old Trex 2X deck board I make stuff out of but I believe it is put together from recycled plastic. Used it under new porch post to keep them off the concrete to keep the bottom from rotting but don't know how it would work trying to turn it. Like earlier stated, watch the heat.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25259 |
Posted: 14 May 2020 at 8:54pm |
A lot depends upon the speed of the shaft or whatever is in the bushing. Low speed = not much heat...UHMW plastic would be better, or a bronze bushing in the plastic... One of those gotta know th eapplication first to decide what's the best material.... |
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5181 |
Posted: 14 May 2020 at 8:55pm |
If you're going to machine plastic use sharp HSS tools. If you get a lot of tool marks take a honing stone and just take the keen edge off.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55288 |
Posted: 14 May 2020 at 9:09pm |
I believe that trex IS UHMW. Saw something on how they turn UHMW recycled milk jugs into them deck boards...
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 14 May 2020 at 9:28pm |
Deck boards are some type of pine or fir... very soft .... not good bearing material
Thad in AR.
Posted: 15 May 2020 at 5:57am |
Thad in AR.
Posted: 15 May 2020 at 5:59am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 15 May 2020 at 6:38am |
Relatively low, you don't want unnecessary heat at the cut. If you can sharpen a carbide bit really sharp, you'd be OK. A carbide insert is not sharp enough to work well. It will work, but not great. You can really put a sharp edge on HSS. |
Thad in AR.
Posted: 15 May 2020 at 6:51am |
Thank you. I’m taking notes. I’m in the learning stages of HSS sharpening. |
fixer1958
Posted: 15 May 2020 at 8:05am |
My father in law wanted some bushings made for some kind of old implement he had and we made them out of hedge. He said it worked and we did that a lot of years ago and haven't heard anything since. I know he still uses it cause he don't get rid of anything.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4279 |
Posted: 15 May 2020 at 8:44am |
There is a composite product, Micarta. I'm not sure what exactly it's made of. It's sort of like wood but different. We used it a lot for fixturing at Maytag. I'm sure McMaster-Carr carries it. Machines pretty good, second the use of HSS tools for cutting this type of stuff. I would think it would work good for a chain tensioner type of application or similar where oak was used in the past.
thendrix
Posted: 15 May 2020 at 11:54am |
Since you're talking notes, carbide tools, especially interested tools, have a less keen edge than HHS tools do. I've been told this is because carbide doesn't shear like HHS does, it's more of a beating action. The rounded edges on inserted carbide tools will do more "pushing" soft materials than actually cutting them. If this material is UHMW and you're milling it I would say with a 2 or 3 flute 1/2" HHS end mill on a manual mill you could run in the 1500 RPM range and be ok. A smaller end mil run a little faster and a little slower for a bigger end mill. Adjust your feed and speed according to your desired finish and what how it feels. When I used to cut plastics I used aluminum vice jaws with sharp or almost sharp dovetails cut in them. I found with straight jaws you kinda get a push upwards on the part from gripping on the corner. The dovetail grips above the corner and tends to hold better. Also with plastics, if you put a piece in a vice and tighten it then go to lunch, when you come back tighten the vice just a little. Like said before UHMW is basically a milk jug and it will form to pressure if left for a while. The good grip you had before lunch can turn into a loose projectile after lunch
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 15 May 2020 at 1:58pm |
Hard maple then pressure soak it oil! ---ALL of the old equipment used them.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 16 May 2020 at 10:02pm |
I thought about hedge when I made a BEARING FOR MY OLD DISC. It's so dense, it might not soak up enough oil or grease to keep it lubricated. With a low speed and little use, it wouldn't have really mattered, but I grabbed what was close and easiest to get at and the mulberry has lasted for 4 years now. Just pump a couple pumps of grease in it every once in awhile. |
1951WDNWWI
Bronze Level Access
Joined: 11 Jul 2011 Location: NW Wisconsin Points: 125 |
Posted: 23 May 2020 at 11:12am |
Lignum Vitae wood is used on ships. Battleships, destroyers, etc... Very hard and self lubicating. It also has agriculture applications as bearings for disk and conveyors.
Edited by 1951WDNWWI - 23 May 2020 at 11:17am |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 23 May 2020 at 4:15pm |
Back in the day,,Macarta (sp) was used in several similar applications but was very expensive until the oil impregnated plastics kinda phased it out,,,
Thad in AR.
Posted: 23 May 2020 at 7:15pm |
Joe I haven’t had a chance to try this yet but I plan to holesaw some blanks and give it a try. Should be very weather resistant. |
