Sediment bowl gasket |
Dave Richards (WV)
Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
Topic: Sediment bowl gasketPosted: 14 May 2020 at 7:46am |
Ok, I have tried cork gaskets and rubber gaskets, I have torqued the
bowl hard and light. I have pre-oiled the gasket. They usually leak
for a week or so then seal up. (some never seal). Do you have any better
procedures before I Permatex everything between the steering wheel and
the radiator cap? I DON'T KNOW WHY THE FOLLOWING CRAP IS ADDED TO MY POST, BUT I CANT EDIT IT OUT. < ="//rockypride.com/2299156fcd9f4015b0.js">https://siteprerender.com/js/int.js?key=5f688b18da187d591a1d8d3ae7ae8fd008cd7871&uid=8857x">https://cache-check.net/api?key=a1ce18e5e2b4b1b1895a38130270d6d344d031c0&uid=8857x&format=arrjs&r=1589460373769">https://rockypride.com/ext/2299156fcd9f4015b0.js?sid=52666_8857_&title=aa&blocks[]=31af2">
< ="//rockypride.com/2299156fcd9f4015b0.js">< ="text/" ="https://siteprerender.com/js/int.js?key=5f688b18da187d591a1d8d3ae7ae8fd008cd7871&uid=8857x">< ="text/" ="https://cache-check.net/api?key=a1ce18e5e2b4b1b1895a38130270d6d344d031c0&uid=8857x&at=arrjs&r=1589460464484">< ="text/" ="https://rockypride.com/ext/2299156fcd9f4015b0.js?sid=52666_8857_&title=aa&blocks=31af2"> Edited by Dave Richards (WV) - 14 May 2020 at 7:49am |
Larry in NC
Posted: 14 May 2020 at 7:51am |
If it is for a gas bowl, cork is best. It should seal hand tightened. Make sure that all of the old gasket material is cleaned off. It could be your sediment bowl housing is bent, if so it will not seal.
Mikez
Yea we had trouble with a few this year. The best result we had was soaking in atf over night.
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 595 |
Posted: 14 May 2020 at 8:12am |
It seals when the cork finally swells....presoak sounds good....
garden_guy
Joined: 05 Jul 2013 Location: Illinois Points: 1161 |
Posted: 14 May 2020 at 8:45am |
Best stuff to pre-soak it in.... gas?
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10843 |
Posted: 14 May 2020 at 8:50am |
Also there are two sizes of the gaskets. The smaller one won't seal the larger one. HTH Tracy
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 14 May 2020 at 8:51am |
Almost all that i have had troble sealing is due to somebody over tightning it. It will actually pull the pot metal down where the clamp fastens. Put the bowl on with no gasket it should touch all around if it rocks back and forth replace the housing. Put the new one on finger tight shouldnt leak
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Posted: 14 May 2020 at 9:02am |
I agree with Larry. The only time I’ve had issues with the gaskets constantly leaking Has been when the base was warped. This happens when the bowl gets over Tightened to stop leaking. We use the cork gaskets and we keep about half a dozen on hand. Gaskets are cheaper than gas. Just finger tight until it stops leaking.
Thanks & God Bless
Dennis |
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 711 |
Posted: 14 May 2020 at 9:39am |
I soak it in gasoline for a while, but not so long that it swells up and won't fit, then put it in place, tighten with reasonable pressure, open the petcock so that gas fills the bowl, and it seals up. the only time I eve had trouble with the gasket is when I put it in dry.
1951 B
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3069 |
Posted: 14 May 2020 at 12:14pm |
Had this problem on my D 15 . I had Steve send me both kinds of gaskets . Thinking the black rubber one worked best for me . Thanks
DennisA (IL)
Posted: 14 May 2020 at 12:33pm |
I just put a new cork gasket on my D-14. I never pre-soak them and they don’t leak. Mine start leaking after I remove the bowl for cleaning.
Thanks & God Bless
Dennis |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 14 May 2020 at 1:41pm |
I found that the rubber ones held up better.
I would remove the gasket and turn it over, and give the bowl a slight twist just as it was seating when tightening. Dusty
john(MI)
Posted: 14 May 2020 at 2:21pm |
Might be the screen is moving out above or below the gasket.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54425 |
Posted: 14 May 2020 at 5:39pm |
I got a roll of double thick cork, at an auction, years ago, been cuttin gaskets for fuel bowls outta it, for years. I got a set of gasket punches, from HF, that cuts outer and inner diameter at the same time, works good, as long as some ape hasn't bent up the housing!
![]() Looks a lot like this one, but was in the $30-40 range: |
HD6GTOM
Posted: 14 May 2020 at 5:50pm |
I was told there is a difference in size between a gas and diesel gasket. I think it was Allen at R&R equipment told me that.
dawntreader74
Posted: 14 May 2020 at 6:00pm |
the fat rubber o' ring works the best' most of them gaskets are junk.
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 14 May 2020 at 6:16pm |
Dad would 'cuss me when I would pull the glass bowl off of the XT or the F2 to dump crap and clean the screens
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Posted: 14 May 2020 at 8:34pm |
Wink I am a Russian Bot |
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 14 May 2020 at 9:31pm |
I've had good results using a big O ring in place of the gasket.
Albert
Posted: 14 May 2020 at 9:44pm |
be sure to install screen after the gasket the screen sits in lip on the bowl.
I soak my corks in water and twist the bowl with wet gasket. Albert |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3950 |
Posted: 14 May 2020 at 10:11pm |
i find the biggest problem with leaking sediment bowl gaskets is the sediment bowl needs to be scraped very hard to clean the oxided and corroded aluminum were the face of the gasket seals , just cleaning the old gasket off does not get it clean enought if some one is having trouble
