12 Cylinders and twin turbos hard at work |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Topic: 12 Cylinders and twin turbos hard at workPosted: 13 May 2020 at 10:27pm |
Just not in one unit! Finally had a decent day for some open air cultivating. The 190XT running a paltry 15' International Vibrashank. The D21 is mated to a 1300 silent weed killer that measures out at 27' at the widest point! It didn't look that big with the wings folded up. Sink it in the ground too deep and the D21 stops in its tracks. I didn't put fluid in when I put new tires on the back. Second guessing that decision now... ![]() ![]() |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 14 May 2020 at 6:56am |
Don't sink them in too deep, you may bend the shanks. BTDT. I don't know your operation but I don't need to dig deep. I chisel first and only use the 1200 as a final pass to incorporate fertilizer and pre emerge 2 or 3 inches deep.
Wink I am a Russian Bot |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 14 May 2020 at 7:44am |
Great orange field photo’s - thanks for sharing. If possible, try reducing your AC 1300’s shovel size down to 4” (10cm) width. For convenience, try adding 1or2 300lb rear wheel hub outer cast donut weights to each side of your D21, instead of adding fluid.
Is your XT a series II? Is it’s rear tires 38”? Wish mine looked that great - someday... Edited by AC7060IL - 14 May 2020 at 7:47am |
DSeries4
Posted: 15 May 2020 at 9:27am |
The shovels are very worn, so probably didn't make it easier to pull. I definitely do not want to add fluid to the rears, so maybe if I get lucky I can find a set of weights cheap! The 190 is a 1967 Series I with 18.4 x 34 BKT rears. Finished a very expensive restoration 2 years ago, but it's good to put it to work when you can.
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2733 |
Posted: 15 May 2020 at 2:34pm |
Nice looking outfits. Lonn's right about not too deep with that field cultivator. 3" normal, 4" at a maximum. Just deep enough to get a smooth, level surface.
I'll bet they're fun to run.
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 15 May 2020 at 2:38pm |
Or beet juice, although that aint cheap either
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
DrAllis
Posted: 15 May 2020 at 5:49pm |
Field cultivators and their Owners are funny. I had two Customers with 7040 tractors that were pretty much identical in tires/duals/weight and HP. One bragged about pulling a 26 ft field cultivator at 5+ MPH and the other thought 20 ft was plenty most of the time. What a difference one inch of depth can make and the width of the sweep !!!!
Edited by DrAllis - 15 May 2020 at 5:50pm |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2609 |
Posted: 16 May 2020 at 5:18am |
Love your post caption D series4, everybody and their Uncles are going to click on that baby.....and your pics are great too!
DaveKamp
Posted: 16 May 2020 at 7:11pm |
Great pictures! Wish I could enjoy a couple passes of seat time on one'a those! I remember my Grandfather interjecting into two younger farmers' bragging duel about their cultivator rigs. He said something to the effect of: "Silly to argue about it- I worked both your daddys' fields long before you were born. You got a riverbottom field that is all sandy loam, I've been through it with a huge cultivator like butter on my small tractor... and HIS is a clay hillside, can't cut through it with half the steel and twice the tractor..."
