PTO clutch
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: PTO clutch
    Posted: 13 May 2020 at 5:23pm
Have a 49 B with a 3 pt hitch, and use a 5' finish mower, can't raise mower up unless pto is engaged.   Is there a clutch available to go between the pto and mower gear box so blades can be disengaged with pto running?  Thanks, Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 5:47pm
In a word, no.  Maybe somebody has rigged one up to do this, but its not gonna be something you can find, on the shelf, or add to the driveline type applications...Wink
Edited by DiyDave - 13 May 2020 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 5:58pm
Guess I'll start looking for some junk to experiment on.  Thinking of an electric clutch like on a lawn mower??
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 6:37pm
Put a separate Hydraulic pump on it.  I don't know if it's ever been done, but that would solve your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 9:16pm
Separator clutch from a Gleaner L or M combine would be big enough.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 7:41pm
MACK is this clutch electrically operated or manual?  Thanks, Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:07pm
Electric.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 8:08pm
Update:  decided to use a belt drive with a tension idler,  mowed some with it today and worked pretty good.  Got some pics, if you're interested just drop by and I'll share pics,, or just maybe give a short look see.  In other words my smarter than me phone won't give up the pics.......I'll try the camera tomorrow........
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:07pm
Finally a pic,,,,whew!!!!!   Keep in mind this is before  clean up and paint...
Thanks, Tim
Edited by TMiller/NC - 26 May 2020 at 9:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:58pm
That should work. Better than getting pushed in a pond.       MACK
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 9:49pm
Very clever. Any chance you could post a couple more photos to show the tensioner "closed" and the linkage from the operator's seat? Thanks.
Dave
WC, CA, D14, WD45
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2020 at 11:08am
Well----That should work! actually it looks great and if you have mowed with it and it holds----YA got it whipped! GREAT idea and GREAT job on it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2020 at 12:58pm
Dave,  I've  taken it off for clean up and paint, will try to post more pics when it's back in operation.  Thanks, Tim
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2020 at 1:47pm
Tim, I must say, that is an ingenious way to overcome the obstacle of getting away from the blades turning when you engage the PTO.  I'm interested in seeing how you "beefed up" the apparatus you constructed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 6:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 6:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 6:18pm
a couple of pics of pto belt drive
 1st pic operating lever in off
2nd pic lever engaged
rear view engaged
Edited by TMiller/NC - 30 May 2020 at 6:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 6:33pm
disengaged
linkage under seat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 9:09pm
Very slick! Thanks for the pictures. The creativity on here never ceases to amaze me.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 9:35pm
I think the shift "knob" is from a 46 chevy, came from some things of my Dads.
This page was generated in 0.162 seconds.
