3 Point Conversion for D17 opinions |
Page 12> |
Strokendiesel002
Topic: 3 Point Conversion for D17 opinionsPosted: 13 May 2020 at 4:20pm |
Afternoon!
I'm finally ready to buy a conversion kit so I can use some additional implements, and after shopping around I'm a bit surprised at the differences between some of the sellers. I've settled on the drawbar mounted conversion as most say the sway block is preferred over the chain method. Anyone have any experience with the kits offered through Steiner or OK Tractor? Any others that I should be looking at? Thanks and I hope everyone is doing well! |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25269 |
Posted: 13 May 2020 at 5:30pm |
I chose 'door #3'. I've converted my 3PH implemnts to Snap-Coupler. Ok, I'm NOT a 'real farmer' but I found dealing with 3PH to be a PITFA compared to Snap-Coupler. Really, the 5' rototiller is a 'hybrid' setup. SC with a top link. The toplink is BOLTED to the rototiller, so after the first adjustment, it NEVER has to be played with. While this cost me a bit in material( adapter and toplink) it saves me BIG $$$ at the chiropractor and time !! Instead of fighting to get 3PH on... 60 seconds and I can till the wife's garden... Might be an option for you ??
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55292 |
Posted: 13 May 2020 at 5:45pm |
My favorite is always, the OEM "wishbone adapter" it was engineered, for the tractor, and the traction booster system...
Strokendiesel002
Posted: 13 May 2020 at 6:18pm |
Thanks fellas
DrAllis
Posted: 13 May 2020 at 6:34pm |
A real drawbar would be a "Yes". Real sway blocks would also be a "Yes". I think the biggest question for me would be Cat #1 or Cat #2 ?? and will there be implements for both sizes ?? And then, how many 3 point implements will the tractor be handling?? Quite honestly, there are many implements that can have an adapter made to leave on them and utilize the snap-coupler tractor. This is especially true if you can fabricate things.
Strokendiesel002
Posted: 13 May 2020 at 7:28pm |
Dr-
Cat#2 is what I'm told the kits that have the block that get bolted to my existing drawbar are. I only have 1 3 point implement at this point that I would use, however there are multiple implements that I have t opportunity to borrow from time to time. I don't intend on ditching my snap couplers, as if a SC implement shows up locally and reasonably priced for the extent that I'd use it, I would be glad to have it (back blade, scoop, what have you) I have a pull type mower that I use for keeping a trail around the field (long time friend who's actually a farmer mows and bails it) and trails through my land behind the field, but I'd really like to be able to use the 3 point mower I have as well. One main reason I want the 3 point is to have a bar with 2" & 5/16" ball spanning across for moving the trailers around without constantly getting on and off the tractor. At that point, I may as well just use the truck, but I like running the ole girl :) |
jaybmiller
Posted: 13 May 2020 at 7:57pm |
re: One main reason I want the 3 point is to have a bar with 2" & 5/16" ball spanning across for moving the trailers 20 years ago...when I got 'Troy', I ditched the loader and made myself a Snap-Coupler 'carryall' using forklift forks and a 2" receiver. the forks are GREAT at moving heavy things like 3400# logs( not 3600# , I tired....). The 2" receiver allows me to sleeve in a 2" ball or 2 5/16" to haul trailers ( I do that a lot....) OR pin in a balless sleeve that I use as a 'drawbar'. That works great at moving my 2000 Gallon empty water tank built on a semi frame. yet another 'option' ?? Jay
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 13 May 2020 at 8:34pm |
I put a 3 point on my D17 I like it. But as mentioned the Allis Snap coupler system is one of the best. I hooked up my 3 Allis plows so easy on the WD45 with the snap coupler, it was just a joy after fighting a std 3 point attachment.
Not sure where this kit I have came from? It was on the WD45 I got a few years back. ![]() This kit does attach to the drawbar. I made the top link bracket. ![]() Regards, Chris
Edited by Sugarmaker - 13 May 2020 at 8:49pm |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3252 |
Posted: 14 May 2020 at 7:15am |
Bought my wishbone style 3 point from Jim . Works well . It's on my D 15 and it's cat 2 . Only snap coupler implement we have is a 3 bottom plow we never use . Thanks
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 14 May 2020 at 8:03am |
I’m an Allis guy but let’s be honest was at best the third best option at the time. Thankfully most of my tractors are new enough that’s not an issue. Between snap coupler and traction booster definitely Allis’s biggest design errors. Makes 3 point the standard was the right move.
jaybmiller
Posted: 14 May 2020 at 8:12am |
You must have the 'charm' to get 3PH implement off and on as I've never had luck, especially on lumpy ground, wet dirt, etc. I don't have a nice level concretet pad to change implements and the old body is saying NOT to push,pull, lift heavy 'things' anymore.... I no longer have the time to waste on 3PH, less than a minute to get tiller on and into the field with NO adjustemnts, NO stress and NO hernia.
Strokendiesel002
Posted: 14 May 2020 at 9:04am |
Fellas -
Good thoughts all around. I really do appreciate it! Jayb - would you be willing to share some pics of that setup? Chris - thank you for the pics! Is that a special "pulling" drawbar I spied? I have been thinking about getting another drawbar that I can shorten up after reading and seeing the advantages Thank you again! |
Strokendiesel002
Posted: 14 May 2020 at 9:06am |
AC - thank you - is Jim OK or Steiner?
DrAllis
Posted: 14 May 2020 at 9:08am |
Each has it's own design pluses and flaws. A 3-point hitch that doesn't have the "extendable" lower links is difficult to get hitched to many implements. Snap coupler is unique to itself. I'll tell you this, when moldboard plowing, the snap-coupler hitch, on a 3 or 4 bottom fully mounted plow, is superior to a 3-point hitch in rock country. Almost every rock you hit with a 3pt, you'll shear a bolt or trip a bottom. The snap-coupler hitch allows the plow to be tossed out of the ground sideways in many cases, and avoids damage to the plow. Been there dun that with a 170 and an S4 D17 in the same rocky field with 70 series plows.
Sugarmaker
Posted: 14 May 2020 at 9:26am |
Stroken,
That is just a temp draw bar from a WD series tractor I put on to try the 3 point set up. I do have a custom pulling drawbar, (shorter) for the D17 also. Good luck with your conversion to 3 point. I was just running the 272 groomer on the 17 today. The right adjuster had unscrewed out about 4 inches. Guess I need to zip tie that, or wire it? Regards, Chris
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 14 May 2020 at 10:08am |
If you need a 3pt get a series IV D17. anything earlier or smaller from and for an Allis Chalmers is a piece of crap. The best option for smaller older tractors is the factory (or a copy) wishbone adapter and hook it onto the equipment first and then attach it to the tractor VIA Snap-Coupler. One great advantage the Snap-Couple has over any other hitch system INCLUDING EVERY 3pt is that when an implement is removed from the tractor, all the adjustments remain as it was last being used. Which makes returning to the task a breeze, no need to spend a few rounds getting the implement adjusted again. 3pt equipment is a great way to ruin your back, pinch your fingers and learn new cuss words.
Edited by PaulB - 15 May 2020 at 9:08pm |
John (MO)
Posted: 14 May 2020 at 10:27am |
I don't think you can beat the Cross Mfg conversion that mounts on the AC snap coupler drawbar.
Tony.Or
Posted: 14 May 2020 at 11:32am |
Sugar Maker ! That is a Cross Draw bar mounted hitch , Less the sway control. Tony .
Sugarmaker
Posted: 14 May 2020 at 12:06pm |
Tony,
Thanks I dont know what the sway control looks like? Maybe I need it? Regards, Chris
ACinSC
Posted: 14 May 2020 at 12:08pm |
Jimmy , I bought my 3 point from Jim at OK tractor . Think my son got his from Tony . Might be a good idea to give either one a call ? Thanks
jaybmiller
Posted: 14 May 2020 at 12:17pm |
Bill(MO)
Posted: 14 May 2020 at 2:25pm |
I picked up one from Cross Mfg for my CA. Works good.
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2077 |
Posted: 14 May 2020 at 3:41pm |
it’s sad that the 3 point system won the day. It’s such a pain in the a** to hook up and doesn’t work as well.
Thanks & God Bless
Dennis |
tomstractorsandtoys
Posted: 14 May 2020 at 9:17pm |
Twenty five years ago when Dad was buying and selling used tractors and equipment he sold a dozen or more of the ones from Cross Mfg. Never any complaints except from the post office as they would ship them US Mail. Mail carrier would sometimes bring them out in the trunk of his car but often we had to go get them. They were a nice made hitch. Tom
victoryallis
Posted: 15 May 2020 at 7:06am |
Removing and reinstalling the drawbar on a 17 is a added pain enough imagine on a 300++ horsepower articulated tractor. I’m amazed by the color blindness.
ACinSC
Posted: 15 May 2020 at 7:16am |
Tom I remember when UPS brought my hitch . I was in my shop behind the house and the driver parked in the street and carried it up . Asked him why he didn't back up the driveway and he said it wasn't that heavy . Pretty heavy to me . Of course they'd lost half of it , which came a few days later. Thanks
DrAllis
Posted: 15 May 2020 at 7:33am |
As a 15-16 yr old, dropping the drawbar off of an S4 D-17 was easy. Throwing the whole thing back up in there as one unit was a struggle. It was just about as heavy as a 190XT drawbar. Interesting how the 3-point hitch had to evolve into having a quick hitch on it as it got larger and larger. I think the snap-coupler drawbar/weight issues could have been overcome had it been continued on to bigger tractors.
jaybmiller
Posted: 15 May 2020 at 7:43am |
re: Interesting how the 3-point hitch had to evolve into having a quick hitch on it as it got larger and larger yeesh, they have them for all the 'little' tractors now too, including my BX23S ! A lot of guys complin though as 'CAT1' implements do NOT fit properly, PTO shafts too long, etc. I still haven't put the 3PH on it though, lil digger is real useful... and there's always a D-14 nearby !
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4280 |
Posted: 15 May 2020 at 8:54am |
I've got one (for a 17) that came on my NF 45. It didn't work well at all. I tried and tried to make it work and finally gave up. I stripped most of it to bare steel and repainted it. Need to get the top-link bracket welded back together and see if I can make this thing work on my 17. Memory seems to be the big problem here.
DrAllis
Posted: 15 May 2020 at 9:07am |
Any add-on 3pt hitch that doesn't utilize the lift latches (or lift arm extenders) will always be a second rate hitch, due to the lack of lifting and lowering height. Also, the top link anchor that has only one hole, makes the hitch hard to adjust to lift and lower properly. On some implements you'll get along fine and others, you'll never be happy.
Page 12> |
