Gas tank for D-10 Series lll |
Post Reply ![]() |
BV ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Bono Arkansas Points: 486 |
![]() ![]() ![]() ![]() ![]() Posted: 11 May 2020 at 12:38pm |
where can I find a gas tank for a Series lll D-10, also has anyone used red kote to line the inside of a tank before and the pros and cons, thanks again
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5107 |
I been looking for one that is rusted out, bent in, shot at, or for any other reason unusable for a working tractor. There has to be a bad tank out there somewhere, but no leads that bear fruit. Finding a good one will be harder yet.
Roach ![]() Silver Level ![]() ![]() Joined: 30 Jan 2013 Location: Wheeler, IL Points: 280 |
I have used Red Cote on several tanks with good results. Main thing is the tank needs to be as clean as possible. I put mine in old seed cleaner that tumbles and put about a gallon of gravel. Wash out with soap and hot water two or three times and let dry completely. There is also a pre cleaner you can also use. After putting in the Coating, make sure you get all the excess out and let dry for several days. Neighbor didn't clean well and left too much in the bottom and it bubbled up. Now way to get it out so had to get a new tank.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54141 |
https://www.allischalmers.com/forum/cleaning-out-fuel-tank_topic66696.html
Scroll down to the picture...
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5025 |
I've never used the Red Kote, but I have done a couple with some stuff I got from Eastwood and had good luck. As with most stuff like this, surface prep is very important. It has to be perfectly clean for any product to work and last.
Here is the link for the stuff I used:
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 474 |
That Red Kote works great! I've done several tractors & and a 1960 f-100 that I got a gallon paint can half full of rust out of, that was bout 10 yrs. ago never had any problems since !! Follow directions on can , when you think it's dry wait one more day!!
Ranse ![]() Orange Level ![]() ![]() Joined: 11 Mar 2016 Location: Tennessee Points: 775 |
I can't remember what it's called, but the stuff I used was blue. I got it at Carquest but I think DJs sells the same stuff. I've seen a blue flake or two in the sediment bowl but no major problems. What everyone says about prep is true. It says on the can it will seal and lock in rust, but you don't want a lot. The cleaner the better.
Post Reply ![]() |
