Iso single action high pressure low volume cylinde |
Trauschg
Topic: Iso single action high pressure low volume cylindePosted: 10 May 2020 at 12:07pm |
Iso single action high pressure low volume cylinder to run wheel disk behind wd45 thanks for the help in advance
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1046 |
Posted: 10 May 2020 at 5:15pm |
Just put any cylinder that will fit on it. All the talk about a high pressure cylinder is 100% "BS". Have done it for years with no problems.
Trauschg
Posted: 10 May 2020 at 5:25pm |
I'll just convert a double action by installing vent thanks
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: 10 May 2020 at 6:53pm |
especially if you go to hold position after stroking.
DrAllis
Posted: 10 May 2020 at 7:43pm |
Well, in defense of the hydraulic cylinder builders, back in the days of AC high pressure system (3400 to 3700 psi), an "M" Farmall was I believe only 1,000 psi, so he&& yes, there was a difference in them. But, today's modern cylinders are far better than that. If you are a sharp operator, you can tell when the disc is almost to the top and just return the lift/lower lever to hold. It will only spike at high pressure when it hits the top and then a couple seconds later.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 10 May 2020 at 7:56pm |
re: All the talk about a high pressure cylinder is 100% "BS". Have done it for years with no problems. kinda like playing Russin Roulette....... A good 1000PSI cylinder will be tested at 3000# ( typically 3x the rated normal pressure), same as air tanks ( 300# tank, tested at 900# ) plumb a worn 1000# cylinder to a real good 3800PSI pump... cycle it a few times... it'll blow, eventually, same as Russian Roulette.. a 1500# cylinder would be burst tested at 4500#....maybe.... and just WHERE was the cylinder made ???
MACK
Posted: 10 May 2020 at 8:57pm |
Your big bolted together cylinders will be slow to lift plus after using for a while. It will stretch the bolts to where it will blow end seals. MACK
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 11 May 2020 at 6:45am |
I have some used Factory high pressure AC cylinders available. One of them is a 2 way. You can email me directly at: the1orangewizard@gmail.com
Edited by PaulB - 11 May 2020 at 3:04pm |
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2164 |
Posted: 11 May 2020 at 7:54am |
How do you tell a high pressure cylinder from a low pressure one?
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
jaybmiller
Posted: 11 May 2020 at 8:04am |
you'd hope the cylinder has some kind of MFRs part number on it..... BTW a couple hydraulic sites say the burst ( test) pressure is 4X !! not the 3X I was lead to believe.... so a 1000# cylinder 'shouldn't ' fail at 4000PSI which is more than most A-C pumps put out...
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 1003 |
Posted: 11 May 2020 at 8:05am |
Where are you at in Ohio? I'll check, I might have one.
Life is simpler when you plow around the stump.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 11 May 2020 at 8:13am |
A "worn" cylinder??? About the only thing I ever saw worn was the seals, ….which BTW would bleed a little pressure! LOL I've got cylinders around the farm that are probably 60 years old. I did have an old cast iron cylinder split LENGTHWISE when the tail wheel of a plow slammed over a rock or something. Didn't know it until the end of the row when the plow wouldn't lift and oil sprayed all over the back of the tractor. |
DrAllis
Posted: 11 May 2020 at 8:38am |
Official A-C high pressure cylinders are never larger than 2 inch in bore diameter. In fact, I think 1 3/4" is the largest I remember.
SteveM C/IL
Posted: 11 May 2020 at 10:49am |
Allis hi pressure cyl are "skinny "compared to anything else. I know they made 2 different diameters. I have a couple of each but don't know diameters.
MACK
Posted: 11 May 2020 at 10:02pm |
Hi pressure screw together lo pressure usually bolt together. MACK
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 12 May 2020 at 11:07am |
i would bet the pump isnt putting out anymore than 2000 anyways unless it has been worked on recently
