H3 Dozer
Sgilles View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sgilles Quote  Post ReplyReply Direct Link To This Post Topic: H3 Dozer
    Posted: 09 May 2020 at 4:06pm
Hello all, new to the forum. I have recently acquired a h3 dozer that has the capability to be a power six way blade. Does anyone know where one could acquire the side to side tilt cylinder? Or an equally heavy replacement? Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 6:05am
welcome, sniff ,sniff.. I always wanted an H3....
if you have the cylinder, a shop could rebuild it...
may take a few days for an H3 owner to reply...might not be too many.
try googling 'allis-chalmers H3 tilt cylinder specs' ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sgilles Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 4:03pm
Thanks for the welcome, the h3 didn’t come with the cylinders for power tilt and side to side blade adjustment. I was looking to acquire originals or find out the specs for the stroke on them similar could find replacement cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 4:35pm
Just have to wait a bit.... I assume the HD3 is the same setup as the H3, and lots of them around..... Someone will probably post a 'link' to a manual.....
Jay
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 10:33pm
No pics no link
HD3
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 7:56am
You might try Summerix Implement in Lachine, MI. Speak to Ivan.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 8:59am
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:01am
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 10:03am
Surplus Center - has many hyd cylinders and you might find something to work .
son has been buying cylinders from them for his skid loader attachments , but he just bought 2 cylinders off e-bay for a special puller he is building - his supplier he used last time said they were out of production - but he found 2 on e-bay $200 cheaper . After they were delivered the other supplier said they were back in stock but $100 higher than last order .
 So looks like a lot of suppliers are now competing for business -
Other thing some hyd shops will build to order for 1 of use
Hyperpack View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hyperpack Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 1:14pm
I have an H3  for many years, If I were looking to add a cylinder there I would put slightly larger one on there. Mine is weak tilting on one direction on really hard ground with a loaded blade.
Hyperpack
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 5:47am
might try Thill Track and Tractor in Eau Claire, WI.  http://www.thilltractor.com/
This page was generated in 0.500 seconds.
