side winder |
Post Reply ![]() |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
![]() ![]() ![]() ![]() ![]() Posted: 09 May 2020 at 2:31pm |
![]() I call this my side winder. I have a lot of pine trees with branches that hang down to the ground. this works real nice Dusty
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24731 |
oK, THAT'S NEAT !!! NOW.... what's the specs on the electric motor and genny and I asume the drive belt is twisted ??
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
Nice, a lot of innovation right there. I would like one of those but I'm too old and lazy to make it.
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Would be great for mowing the edge of ponds and close to ditches.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88225 |
what HP is the electric motor ?... what is the mower deck width ?
The generator is a 4000 watt duel voltage 115/230 volt. Also a little different is a switch that allows a straight 115 v 4000 watt. It has a 120v 15a duplex and a 230v duplex and a 230v receptacle.
I forget the hp of the motor, but it's about all the generator can handle. I'm running it at 115v just because I had the electrical parts on hand, and I also use it to run other things at times. Dusty The deck is from my 917h garden tractor, 48", I've got 3 of those decks.
Edited by Dusty MI - 09 May 2020 at 8:29pm |
NE GA Allis ![]() Bronze Level ![]() Joined: 17 Feb 2019 Location: Georgia Points: 139 |
That is an awesome rig!! I think I’d use my sickle mower though. Already have all that stuff. Did you size the motor and generator accordingly or just guess?
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s, 1 WD45, 3 D15D’s, 1 D17 |
Dang you replied “seconds” before me
![]() Awesome rig!!
I had the motor in stock, I wish it was a little larger, but the generator might start a bigger motor. It runs it Ok, but it has hands full starting it.
I have a volt meter I watch when I'm running the generator, which is really needed to know where to set the throttle. Dusty
Post Reply ![]() |
