d17 transmission drain plugs |
Post Reply ![]() |
AllisD17AndyOk ![]() Silver Level ![]() ![]() Joined: 06 Apr 2020 Location: Colbert, OK Points: 51 |
![]() ![]() ![]() ![]() ![]() Posted: 07 May 2020 at 9:12pm |
just brought a d17 series lll and want to change transmission and rear end oil. I see a drain plug under the differential, and a smaller plug between it and the right brake housing. What is this smaller plug, do I drain both? Thanks, Andy
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7502 |
Get yourself an owner's manual. It will show you which plugs to remove and the capacities of the reservoirs. They can be found cheap on e-bay and are full of valuable information. Can't think of the small plugs you are referring to, but don't touch them.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
That is the bolt that holds lift ram pin in place. MACK
Thanks Dseries4 for your advice...I have an owners manual and a shop manual, I read both over and over and find nothing showing the location of the drain plugs...please advise which page I need to read for this info...Thanks, Andy
Thanks, Mack, this is what I needed to know, I will now research that in the manuals...You have made me a wiser person...again, Thanks, Andy
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24675 |
When you do drain the rear end oil, be SURE to have TWO (2) empty 5 gallon buckets handy ! If your D17 is like my D14 was, there'll be more than 5 gallons of oil in the diff... ..seems adding a quart of oil to the hydraulic system to get lift to raise , month after month ,year after year, kinda adds up....... there's NO way a 5 gallon bucket can hold 7 gallons of oil ......
Jay, guessing you must have found this out the hard way...according to my owners manual, my D17 rear end holds 24 quarts, that's 6 gallons, but my shop manual for the same tractor says it holds 28 quarts, that's 7 gallons...so based on your experience, I'm gonna have 3 buckets handy...Thanks, Andy
yeah... that was a FUN way to start the day...... I let the plug drop into the bucket......saves the panic wondering WHEN does it get out of the hole....
Post Reply ![]() |
