wd45 full flow oil conversion question |
Post Reply ![]() |
Reallyrusty ![]() Bronze Level ![]() ![]() Joined: 05 May 2020 Location: Northeast Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 06 May 2020 at 6:26pm |
I recently acquired a 55 wd45. It was free including the 2 and a half gallons of water i drained from the engine sump. I am in the process of a complete overhaul and have converted to the d17 oil pump (internal regulator) with all the plumbing changes. I am not concerned with originality as it will be a working unit.
My question is i have a generic oil filter mount that i would like to use for the oil filter. Can i simply "Tee" into the 3/8" oil supply line with a 3/16" line for the head and governor? Will there be too much flow to the head and governor or drop the pressure too much? I don't have ( or seen) the correct D17 filter mount so i am not sure if it meters or restricts the flow. Sorry for the newbie question.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8651 |
Original 17 base doesn't meter the little line and your 17 pump will supply plenty of oil. Assuming you drilled the block and blocked the "in" and "out " passages from each other and have the matching distributor gear,your home made filter idea should work. I'd get the base and lines for a full flow 17 from bone yard but that's me. (what I did). You will need to reshape a line to fit in a 45 and miss the steering.
thank you!
I got to thinking...the fitting in the base for the little line may have a small orifice. I never paid much attention as it came from a 17 and knew that it would work. I'm not going to pull mine apart to see,sorry. A 1/16th in hole would be plenty I would think. I don't know if there is a problem flooding the head through the rocker shaft? Dr Allis would know about the fitting.
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1504 |
There is a whole thread on this in the knowledge section. Take a look at that - it seems to have everything covered. Have never done it myself so don't know for sure. I'm sure others that have can tell you if you need anything else.
I have studied the knowledge section pretty well but i have not seen that one detail. I guess it would be mute if I had the correct filter base. I just figured they must have designed in how much oil they wanted to go up top and the d17 pump is going to change that.
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
I don't think it matters much how much oil gets to the head, it just has to be a constant trickle as it gets distributed evenly to all the rockers. The fitting is the same size as the I.D. of the line itself which is 1/8 tubing, not sure on the wall thickness though. Get the correct filter base and lines if at all possible, it will just be that much less hassle.
I advise plugging drain back hole in block from bypass filter...more sure fire than counting on a gasket .
that has been done along with all the other block plumbing changes that were shown in the knowledge base. the only deviation that i have is the filter mount.
Post Reply ![]() |
