HD 11 Crawler
Fairlady View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fairlady Quote  Post ReplyReply Direct Link To This Post Topic: HD 11 Crawler
    Posted: 05 May 2020 at 5:44pm
I am wanting an approx price to ask for a Hd-11 Crawler.  It does run.  I don't have any pics yet.  I will not be selling it privately - wanting a figure for and estate. Thank you.
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 10:58am
Hi, what you might want to do is find the serial number, it will be either on the dash placard or if you are standing behind the tractor looking forward it will be on the upper right hand side of the chassis, below the fuel tank, it will be stamped into the case. Check and see if it has an hour meter, take pictures of the sprockets in the rear and tracks, and pictures that show overall condition of the tractor as best you can. That will help a bunch, good luck; Tad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fairlady Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 4:58pm
The serial # 6607 model # B329336D.  It does not have an hour meter.  I'm attaching some pics. Hopefully all the pic showed up here.  I had several. I am thinking maybe I can just send one at a time.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 5:15pm
Sadly, only one of the engine showed up.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 1:18am
have a look on the upper rhs rear case. will be some letters and numbers stamped there. Looks to be a later model HD11 with 11000 engine
tits tyres and tracks
they all cost you money
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 4:51am
On the picture I can see he has a instalation turbo on
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 10:02am
Ok...my observation would be 11ep....don't think the serial number is the tractor serial number though. The tracks as I pointed out in an earlier post appear to be the later style 11 tracks...which would mean it should be 10000 serial number and up.  The dash is E/EP looks like.  more pictures.
walnut1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walnut1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 7:42am
it also looks to have spin-on fuel filters.
This page was generated in 1.213 seconds.
