190XT PD
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Topic: 190XT PD
    Posted: 04 May 2020 at 10:43am
Does the 190XT power divider share tractor hydraulics or is it separate?  If separate, where is that drain plug/fill and how much/type fluid?  The power divider works good between lo/hi but does not engage... hard, more like easily slips into high.
I drained the hydraulic fluid, put a new filter on and filled.  Have not operated it since doing so as I'm awaiting a water pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 12:47pm
Hydraulic system is the oil to apply and lube the Power Director clutch. Two drain plugs. Takes about 5+ gallons of oil.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 5:51pm
Both drain plugs are on the torque tube.
This page was generated in 0.087 seconds.
