Honda Mower Blade Observation
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Honda Mower Blade Observation
    Posted: 02 May 2020 at 6:05pm
I run(ran) an older Honda 215 self-propelled bagger mower with the plastic deck and side pull rope start. 1 year ago I bought a new Honda Twin Cut blade as the blade that was on it was shot. I had never seen a blade set-up like that in my life, so didn't know what to expect until tonight Cry. I tagged a root that apparently grew out of the ground earlier this spring Confused. Long sad story short, those blades are ALOT tougher than the crankshaft Ouch. Keep an eye out guys LOL!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 6:29pm
suppose to be an aluminum KEY in the end of the crank to attach the blade holder... That should sheer and protect the crank ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 6:41pm
That was my thought also (key/key way). Mower still runs, shakes like H^#L  though Cry
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 11:45pm
Had the same thing happen about 10 years ago, had a Craftsman walk behind w/Tecumsa(sp) engine, trimming under a tree and snagged a root killed engine dead, restarted and shook like the dickens.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 6:51am
High RPM’s, long crankshaft nose, no support, = bent crankshaft, we saw them by the hundreds when I was at a suburban Deere dealer, it’s not just Honda, it was all colors! We had a jig that you could put the crank in and sometimes straighten them back out, but as cranks got softer and labor rose, it was cheaper to just put another engine on it, or junk it.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 7:33am
Had the same thing happen to a MTD with a Briggs & Scrapiron. Shook so bad you couldn't hold on to it. Never did shear the key.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 9:23pm
dont matter what brand of  engine or blade configuration those cranks will bend easy we get a few dozen of them here every year they mostly end up gettting scraped because theey dont want to fix them and we will not sell or use used parts on any ones equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 5:37pm
If I continue to run this at reduced RPM'S until I can locate a replacement, what's the worst that can happen? I assume a bottom end seal will "elongate" and dump the oil ??
I am "on-the-hunt" for a replacement though Wink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 5:51pm
Take a look at the blade, too. Take it off, lay it on something flat, and see if its bent.  Then put it on a balancer, and see if it is balanced.  You gotta take it off, to fix the crank, or key, anyway...Wink
[TUBE]nzratbmfxkc[/TUBE]
Edited by DiyDave - 04 May 2020 at 5:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 5:58pm
It's NOT the blade, this mower has blade disconnect and it shakes LESS with the blade engaged LOL !! Sadly , this mower owes me nothing and is becoming quite hard to start any more Pinch. I will miss the plastic mower deck WinkWink
Edited by FREEDGUY - 04 May 2020 at 6:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 8:37pm
the mower blade on most of the mower engines is the counter weight for the light weight alumium flywheels so ithe blade adapter is partly sheared or the flywheel key or both it will make it hard to start and  or will try to rip the pull rope out of your hand
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 4:56pm
Some what of an update . Still using the Honda (my palms are still tingling after shutting the mower off 35 minutes ago) but have purchased a used/barely used Toro. My concern is that the engine is either OFF or WIDE OPEN Stern Smile. There's NO throttle lever to feather the engine which seems very strange to me, seems like cold-starts and WOT don't go hand-in-hand Wacko. Is there cause for concern ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 6:18pm
A lot of engines are made that way... CHEAP.....
some have a 2 spring choke ? system however you can bend a tab 'somewhere' to LIMIT the top end RPM. Which tab and which way depends on make/model of engine.
What gets me is having to turn over a Honda mower to drain the engine !!! Then agin some JD riders don't have drain plugs in teh hydro unit either !
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 6:38pm
Jay, I assume you mean roll the mower 90 * ??  I've never had any issue changing the Hondas oil that way but it sure seems like I saw a drain plug under the block when I installed the new (Cry) blade 2 seasons ago but never pursued it. It was a PITA to hold the deck up to change the blade by myself, let alone jack with a seized-in plug LOL!! Thanks for the reply Wink
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 8:49am
That is the way most of them are stamped out now.  Let her rip tader chip.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 5:38pm
Sounds to me you are just a little lazy, a blade change on a push mower is a PITA?  Try changing one on a bush hog!  A siezed in drain plug? 2 minutes work, with a battery powered impact gun, and the right socket!  And I'm being generous, figgerin it takes a minute, to find the gun, battery and socket!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 6:26pm
Well, aren't you "THE MAN" Smile !!
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 7:24pm
The newer push mowers don't have a throttle, choke or primer bulb. Just pull the cord and go. May snapper has been working great. They also no longer have a drain plug to change the oil. If your going to do a oil change you gota tip it upside down and drain the oil out the filler tube. My las one lasted 15 years was still running great when it rusted through the deck. Never changed oil or spark plug. Put a new blade on once sharpened once a summer and cleaned and sharpened when put away for winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 8:39pm
briggs quit  putting drain plugs in push mower size engines 10 or more years  ago .    i do not remember how many millions that our briggs representive told us back then,   that they saved in the cost of the drain plug and the extra machining  but it was a big yearly savings
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 9:10pm
For hard to get at and those engines without plugs, I use a vacuum extractor, kinda looks like a 2 gallon lawn sprayer, but it sucks the oil out, when you pump the handle...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 9:30pm
Well it really 'sucked' when neighbour was told by JD dealership his rider wasn't worth fixin, something he'd paid close to 4500 Canucks.Cry
I can see 'trimming' costs on a $200 mower but.....come on...
same as NO Zerks in car U-joints  I suppose..
No money in making something last....
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 11:33am
Dang you all had HIGH CLASS mowers. First power mower here in the late 60's a Sears you had to turn it over and drain from the filler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 5:03pm
LOL !!! That's EXACTLY how the "newish" Honda mowers are drained !!!!
