Transport rod
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Transport rod
    Posted: 01 May 2020 at 8:56pm
Hello everyone.
Have what I think is the mower transport Rod. The older pitman mowers. Could some one measure there's. When I looked in parts book I see four different part numbers for it. The one we have is about 42" long X 5/8" Rod dia X 7/16 thread dia with like a 45deg bend at thread end. I didn't add the threaded part to the 42".
Thanks
Edited by Mikez - 02 May 2020 at 8:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 10:17am
sure looks like the ol #3
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 10:19am
I’ll see if I can find the one we had but can’t remember if it was for number 3 or 5.
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 12:29pm
Definitely not for a number 3 mower. If you look at Agco parts books for the no. 3 mower on the “main frame” section, you can see that the prop rod also has like a 20 degree bend at the 90 degree end of the rod to clear the hydraulic cylinder. I verified on my no. 3, it needs that 3rd bend.
I measured a prop rod on what I believe is a b and c belly mower and it is about the same length as what you measured.
I am not sure what all the differences are between the no. 5 mower and the b and c belly mower but visually by the parts books, it looks like the frame for the b and c mower is longer than the no. 5 mower. The front brackets on the no. 5 mower that attach to the tractor are angled forward and the bend straight up to bolt to the tractor. The b and c mower brackets only go straight up and down between the mower and the torque tube. Like I said, I’m not sure if those are the only differences but by looking at the parts books, I would imagine that the prop rod for the no. 5 mower and b and c mower are pretty close. The frames look about the same.
Hopefully someone else can verify this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 7:15pm
Thanks.
Like even said, it looks like the #3 has another slight bend in it.
The #5 mower is 803571
The WC mower is 802961
The B-IND is.       802391
The B,B-C mower is 802706
The B-C eff Jan 1941 is 802154
All these are in mower parts book that might look like what I have, if anybody has one they could measure quick for me. Thanks a bunch for the help.
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 7:29pm
my transport rod for WC is about 42 inches
my number 3 rod is about 45 inches
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 8:06pm
Great thanks roger. I didn't mention that I measured from hook end up to about the bend, I didn't add in the threaded part
