200 stopped moving!! UPDATE
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: 200 stopped moving!! UPDATE
    Posted: 30 Apr 2020 at 4:28pm
I was pulling the FC today and when I went to lift the FC the tractor stopped moving. I immediately put the PD in neutral and then tried to move the lever into high or low and the lever felt stiff and wouldn't move into high or low position. I got out and tapped the valve into low and limped it back to the yard. When I would lift the FC with the remote the tractor would stop until I put the remote back to hold position. I'm thinking the PD valve went haywire. Any suggestions? Thank you.
Edited by Lonn - 26 Aug 2020 at 6:14am
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 4:32pm
I unhooked the linkage at the pd valve and it moves freely. I can also move the valve spool by tapping it and it springs back to neutral.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 4:59pm
Did some driving around. So now it won't move unless I move a remote lever, no cylinder hooked now, and it won't steer either, again, unless I remove a remote lever. Priority valve?
Wink
I am a Russian Bot
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 5:06pm
Have you checked your pump output pressure?
Don't hear me wrong, I am not ruling out a valve, but I would start at the source and make sure you have the correct working pressure to start with, and troubleshoot from there.
Edited by Orange Blood - 30 Apr 2020 at 5:07pm
Still in use:
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 9:45pm
Sounds like the flow divider on the pump is sticking. If you have to tap on the power director to get it to spring to center, that is a problem. It sounds like you have contamination in the hydraulics causing them to stick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 9:48pm
There is a plug blown out between sections of pump. Very uncommon, but have saw it happen.        MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 11:13pm
I put the FC on the 7050 and within a few round the cylinder, which was leaking already, blew oil out the end. I removed it and went to switch the cylinder hoses to another cylinder I had on hand and there were bits of aluminum stuck in the pioneer coupler tip. And lots of aluminum and seal pieces in the hose. Threw both hoses away and put new ones on. The hydraulic system is obviously contaminated now, 200 for sure and possibly the 7050. Disapprove
Wink
I am a Russian Bot
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 8:05pm
sounds to me like something in the hydraulic pump gernaded on the 200, when you drain the 200 I would use clean white buckets with cheesecloth and see what you get
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 9:38pm
I'll do that. It's parked for now until I get time.Thanks
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 9:52pm
Just an update..... I just didnt have time to look at the 200. Had dealer take it. I moved it several times over the summer and had to move a remote lever in order to move and steer every time. Went to move it onto dealer's trailer and it suddenly operates fine but I blew a hydraulic line from hydraulic cooler as I drove onto trailer.
I let them take it and told them the hydraulics have always been on the weak side. They flushed out everything and put a kit in the pump. Still low pressure at remotes until 1300 or 1400 rpm. They say I need a new pump but it does steer at idle which it didnt do before. Does this sound like it needs a pump? I'll do it if it needs.
Am I going to be expected to pay for a wasted pump kit? They ordered the kit before they asked my opinion. I would have gone with what they recommended anyhow.
My brother's 190Xt series III has always had better hydraulics than the 200.
Edited by Lonn - 25 Aug 2020 at 9:55pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 7:16am
A very late 190XTIII and 200 and 7000 do NOT have much for hydraulics at the rear of the tractor until throttled up !!! That is the way they are and it is very normal !!!   When I say late 190XT III, I mean the ones that have a 200 hydraulic pump on them, not the old original pump, which was better at slower engine speeds.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 8:11am
Thanks DrAllis. I talked to the mechanic again and he said the hydraulic flow was just a little under new specs so I think a $2000 pump is not warranted at this point especially since it steers at idle which it didn't do before. If I get it home and think different then I can change that out myself when I have time. Right now I can still use the tractor. Thanks again!
Wink
I am a Russian Bot
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 10:18am
You can change that out later yourself.  But you will have to flush the entire system again.  Maybe it's a good idea to have them do it now while the system is not contaminated?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 11:30am
You might be right but tack $2000 plus onto the $1700 I already racked up..... it's getting spencive! I gotta give it some thought for a day or two. Stuck $2000 a couple years ago into the PD ..... what's next?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 11:59am
Is that an Agco pump for $2000? A+I had them for $1200 a couple years ago
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 12:39pm
Yes AGCO. I'd probably go with AGCO for something like that. Easier to return if defective and I'd trust that it will be right. Aftermarket seems to be around $1400 or $1500 from what I've seen.
Wink
I am a Russian Bot
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 5:37pm
I agree Lonn. Fair chunk of change but go with the Agco.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 9:09pm
Before you put new pump on , clean every thing out good. Remove suction pipe, suction screen housing, flush lines, and hydraulic cylinders. Any thing oil is in.        MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 9:16pm
OK thanks guys. It's at the dealer so I hope they flushed everything. I'll talk to the mechanic before I pick it up.
Wink
I am a Russian Bot
