seals for m&w 4 & 1/8 sleeves for WD
rcpulls View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rcpulls Quote  Post ReplyReply Direct Link To This Post Topic: seals for m&w 4 & 1/8 sleeves for WD
    Posted: 29 Apr 2020 at 10:25am
need help finding the 4 &1/8 seals for my WD Allis
any help appreciated
Edited by rcpulls - 29 Apr 2020 at 10:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 6:20pm
I think i would get the diameter and cross section thickness of the o-ring and order .  Probably get them at Auto Zone or NAPA... but surely you can order on line from mcMaster Carr...
here is a reference discussion....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 6:41pm
original rings were probably Buna-N material... These Viton are a little more antifreeze resistant.  You probably need the 4-1/2 or 4-3/4 diameter rings.. If in between, get the smaller size.. They stretch easily...... You need to know if you need .070 , .100 , or .140 ring thickness.
Edited by steve(ill) - 29 Apr 2020 at 6:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rcpulls Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 6:31am
thanks for the info but the problem i running into is the seals are not round
they are wider than they are thick on the m&w sleeves
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 6:53am
Pretty sure they are an odd/special thickness and no longer available. They were round when new and are pretty thin.
Edited by DrAllis - 30 Apr 2020 at 6:53am
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 8:51am
RCPULLS,
We may have what you need.  Let me know the width and depth of the groove on your sleeve. Give me a call (440) 570-3653
Mark Pfouts
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 9:54am
  Been using .093 thick o ring  for years on these .
nonetheless ,still dead.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 4:00pm
Try this place: Global O-Ring and Seal, LLC.
Great people to deal with.
If you go to this site, I'm sure you will be able to get the O-rings you need for your sleeves.
They have groove measurement charts and they can fix you up with any size imaginable.
They also explain what composition O-rings fit what application.
You can speak to them on-line or by phone and they will gladly help
with determining exactly what you need.
