Calling all painters,,,,,
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Calling all painters,,,,,
    Posted: 26 Apr 2020 at 11:02pm
I have a gallon or so (split amounts 3 different unmarked containers), that is gloss and/or semi gloss white latex. I have a ceiling to paint, but want flat white, I know adding water will cut down the sheen somewhat , but is there a better trick to converting gloss to flat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 12:04am
add sum black! no...wait...
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 7:51am
Courtesy of Rick Dale of the History Channel show American Restoration.
"If you can't find a paint color in a flat finish, you can simply mix some corn starch in with any type of paint and the result is a nice flat finish."
The blurb didn't mention any amounts. Also I would make a slurry of some paint and starch, then add some or all of that while mixing well. Less chance of clumps in the paint that way.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 12:05pm
Lower quality paints that aren't specifically made for ceilings can be pretty drippy - you might want to test them first.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 1:52pm
an that chas is just a wealth of knowledge.  Wink
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 2:46pm
I would think adding the corn starch would also serve to thicken up the paint as well
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 3:56pm
I would just go buy some ceiling paint and forget the other stuff. You have to make sure the paint is all boxed together. You start mixing paints and it can be a problem down the road. Flat ceiling paint is cheap enough.
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 4:16pm
I agree!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 10:41pm
rattle can it???
