2300 disc bearing question
OhioWT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OhioWT Quote  Post ReplyReply Direct Link To This Post Topic: 2300 disc bearing question
    Posted: 24 Apr 2020 at 6:40pm
Today, I apart the outside rear gang on a 2300 today that has a center width of 9 feet 6 inches and a fold up set of gangs front and back on both sides. The shaft is hexigon. Both bearings were in flanges. BUT, the bearings were different. Both had a convex outter race, but the outter race on one was widder than the other.   I tried a W208PPB16. It fit the shaft, but the outer race was too narrow and left far too much play in th flange. I tried a W208PP8-IMP. It has flat outter race and would not fit the shaft. I have two of these disc. One has the cast hangers for the gang, and the other has the steel ā€œLā€ shaped hanger. Both seemed to have a rubber gasket or some matterial between the bearing and the flange to keep dirt out.
Any help with finding the right bearning or the right sealed flange/bearing combination would really be appreciated.   Neither old bearing had a nubmer on it.
This page was generated in 0.115 seconds.
