8070 head gasket?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: 8070 head gasket?
    Posted: 23 Apr 2020 at 2:25pm
Yesterday dad was field cultivating with the 8070 when he said he started to smell antifreeze. He shut it off, I went back to start it about an hour later, when it turned over it had lots of white smoke in the exhaust, after a bit it did start but sounded horrible. I set my finger on the radiator cap and you could actually feel compression on the system. Pulled it in the shop this morning, just found the problem. Head gasket is completely gone between 5 and 6. Ordered head gasket set from AGCO. The head looks to be okay, liners feel good look good, Pistons feel good look good. There was a lot of water in the oil, but I plan to let it drip dry for some time. My question is what should I or should I not do in the process of putting this back together? The injectors were done this past winter and a new core put in the radiator. Should I go ahead and have the head sent off? Just looking for any extra information from the guys that know better. Thanks.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 3:53pm
What I would do depends on how many hrs it has on it. How close are you to an overhaul ??  Also, torque head bolts to 150 ft lbs, run for a couple of hrs at full throttle or go to the field for a day under light loads and the next morning re-torque to 165-170 ft lbs when stone cold. Use gun grease on head bolt threads or molycoat paste of some kind. Tappets at .017" COLD.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 4:08pm
A neat little trick a puller friend told me about, is to leave the rockers off, and use 6 more short bolts from a donor engine, and torque all 26 bolts as if the rockers were there. Once torqued down to 165, we pull the 6 dummy bolts out, and set the rocker assy on and torque them. The problem is when you torque the rocker stand long bolts, it loosens the ones under the rocker shaft. The offset tool just flexes too much. After going to studs on my 210, I scavenged a set of stands off an old rocker assy, and slide them on the long studs, and do my usual thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 4:18pm
I have a tool to torque all 26 or 27 bolts at the same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 8:39pm
What kind of a tool do you have? I have one to go under the shaft.       MACk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 6:29am
So, leave hood off don't use permatex on valve cover gasket, start it, bring it up to full running temp for couple hours, let cool down and re-torque. Then button it up.
Thanks.
Leon BMo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 7:07am
My preferred method was to run for a couple of hrs, hit the dyno for 15 or 20 minutes at full load and then retorque in the morning when cold to 165-170 ft lbs. I have an exhaust pipe that sticks out to the side that is held with one bolt so I don't mess with the muffler until I am all done. I never take the top hood off, but that's just me. My tool is an old Snap-on offset to get under rocker arm shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 6:03pm
Okay, I have a crow foot 3/8 drive three-quarter inch line wrench, or 1/2 drive open end crow foot. Is that applicable? Or will that distort the actual torque applied? My retired Ace AC mechanic is under the weather right now and I don't know if I can get his input on this.
Thanks again. Dropped the head off this morning to be planed, dipped, checked.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 6:47pm
Line wrench will not stand 165 ft lbs of torque.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 6:48pm
    This is probably what the Dr is talking about. ½’ drive on top and 3/4 “ bottom 5 ½” clearance. Snap-on S9513C. You can use it if it will work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 8:00pm
Thanks guys for all the input. I'll have several days until the head is ready to try to gather any tools I'll need. Hopefully by then my mechanic will give me his insight or lend me his tools also.
Leon B
This page was generated in 0.049 seconds.
