Latest tractors D 14 - 19 LP |
Post Reply ![]() |
Richardmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Rolla mo. Points: 1746 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Apr 2020 at 11:14am |
Yesterday stop at 3 different places to pick up tractors and a canopy.
about 1000 miles round trip to OK. Thanks to Adam for loading me at 9:00 pm. Some of the trip in the rain was not fun driving. Will get better pictures still raining here today. D 14 propane D 19 Propane ![]() ![]() ![]() ![]() ![]() |
Steve in MI ![]() Bronze Level ![]() ![]() Joined: 09 Jan 2019 Location: Hesperia Mi. Points: 28 |
makes me want to get started on my wd45 lp i picked up a couple years ago
lowell66dart ![]() Orange Level ![]() Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Now you just need a 7045 high crop to put that canopy on!
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Might use the canopy for my 7020 High crop.
Work on the D 14LP yesterday. Had to change out the Coil as it was bad. also they had the polarity wrong for way the battery was connected. Also put about 30% Propane in the tank. Last few D 14 tractors I have bought, had the missing tube out of the oil filter. This one did also. Pull one from a parts tractor, oil pressure is at 23lb. Also changed out the starter. Has power steering and need to work on all the leaks. Still need to spend time on the D 19. The Propane gauge gasket does leak found that out yesterday. Pull the tractors off the trailer using my D 15 Propane. ![]() ![]() ![]() ![]() ![]() ![]() |
steve fischer ![]() Orange Level ![]() Joined: 11 Jul 2011 Location: sleepy eye mn Points: 992 |
I just sold a set of six d19lp piston and sleeves , have two left if you need any
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8506 |
Richard,
Congratulations on the two new Allis LP tractors! We really like to see your pictures as you bring these home. Do you have plans for these two? Regards, Chris
Adam Stratton ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
Glad you made it home safe Richard! Thanks for stopping by. If it would have been different circumstances I would have given you the nickel tour. Hope it all works out well for you.
work on the D 19LP yesterday put a new gasket on the LP fuel gauge was leaking.
It needs all the belts they had been removed. |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
You do get around Richard. You just have to be about the luckiest guy,,,,,,,you're always coming up with strays somewhere to add to the herd. You're worse than a kid in a candy store. CONGRATS and have fun!
I had bought this other D 19 LP early before the swap meet and this weekend we spent time changing tires from a parts tractor that had bought some time ago.
Tires off both tractors where loaded with calcium. Also removed the wheels off the parts U moline, we had removed the motor out of that for the UTC high crop. Also installed set of NOS set of Snap couplers on the tractor, had bought these at the last swap meet. Hook the 4 bottom disc plow on the tractor. Still have to figure why the Snap coupler lift hydraulics will not hold. 2nd radiator for the D 19LP with 3pt seems to holding water!. Had put all new belts on that tractor,ordered new radiator hoses this morning. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
WD45Diesel57 ![]() Orange Level ![]() ![]() Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
do you have any spare three point hitch parts for the D19 i'm looking for the solid winging crank on the lift arm adjustment.
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Sorry no parts, I am looking for more three points myself
Post Reply ![]() |
