Looking for d10 grill shell
D10rebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10rebuild Quote  Post ReplyReply Direct Link To This Post Topic: Looking for d10 grill shell
    Posted: 20 Apr 2020 at 6:59pm
Looking for a grill for my d10. Ot was my grandads tractor and I think he used more like a dozer than a tractor so I’m trying to find a good grill shell. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 8:40pm
Not to steal your thread,I don't have a grill shell, but I do have reproduction grill guards like the original AC ones. HTH Tracy
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 7:23am
Try Paul Barnsley (Paul B on here). He's not too far from you in Maryland.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 5:08pm
The only thing I have here is from the D10 industrial with a Henry loader, it has the bottom cut out for the pump drive. So nothing for a restoration. D10/12 sheet metal is tough to find.  I've been searching for a D10/12 gas tank that's bent up, rusted out or shot at. I can't even find crappy sheet metal.
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 6:11pm
This is a little off topic, but I have over the years parted out several D10's.  Sheet
metal is the first to go.  Folks need fenders, hoods and grill shells, gas tanks.  I stopped parting anything out, first because it is a lot of work and I am getting older, and second parts don't sell nearly as fast as they once did.  You can't buy a D10 or D12 to part out cheap, so you have an initial investment to recover before you can make anything on the tractor.  An individual can not come close to getting the prices that the salvage yards like Wenger's get.
In regard to your grill shell search.   The shells (radiator surrounds) for all three series are the same except the series III shells do not have holes for headlights.  Grill shells from all Series can with used with minor modification depending of the Series tractor you are installing it on.
Edited by Larry in NC - 22 Apr 2020 at 11:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10rebuild Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 9:14pm
Ok thanks guys, I’m sure somthing will pop up eventually.
Jeeper38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeeper38 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 6:18am
When I was fixing up my D12 I got a complete trans and a set of cylinders from a guy in Minnesota. I'll send you a PM with his info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 10:54am
The series III radiator surround is different from the earlier ones. The early ones DO have the headlight hole and DON'T have the holes for the front weight.  Also the grill screens were different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10rebuild Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 1:24pm
What shape is that industrial grill you have, my brother is very good bodyman so i do beleive he could fill the hole for the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 6:23pm
If you can get a D-15 series 2 grille , you may have enough material, to make a D-10/12(series 3) grille out of it.  I think I read somewhere, that someone sells the series 2(3) grille metal, but can't recall where.Wink
Edited by DiyDave - 22 Apr 2020 at 6:25pm
This page was generated in 0.324 seconds.
