Hydraulic cylinder repair
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic cylinder repair
    Posted: 20 Apr 2020 at 9:44am
Any tricks on holding the rod from turning while trying to unscrew the yoke from the end?  There is no flat, on either end of the rod.  When in the retracted position, it is almost completely inside the cylinder, so I don't want to mar the rod or it will tear up the seal.  (and I just resealed it!)
I thought about putting like a strip of inner tube or something on pipe wrench jaws....?
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 10:37am
I use my large bench vise with a 2x4 over each jaw and the cylinder rod in the middle.
It may need a little heat.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 10:56am
For replacement of seals I always leave that end alone and start on the inside end of the rod. But i am guessing your not planning on going that far ? So your on the right track. Maybe a rap of the inner tube and clamp it in a vice,and some heat if the vice is not enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 11:30am
Dan
That's a good idea.  10-4 on the heat.  Just don't want to nick the rod.
Ray, the seals have already been replaced.  As you said, didn't need to take the yoke off for that as I came at it from the other way.  Then after a couple days of use, the yoke broke and needs to come off.  (Technically, not a typical yoke, but I'm keeping the story simple)
Thanks guys.
