I600 diesel crankshaft bolt
Dieselherb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dieselherb Quote  Post ReplyReply Direct Link To This Post Topic: I600 diesel crankshaft bolt
    Posted: 19 Apr 2020 at 8:04pm
I need to retiming my injection pump/shaft on the D175 engine. I'm having a time trying to get the crankshaft bolt loose. Any tricks youall might have?
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 9:08pm
are you just not able to turn the bolt loose?
did you try an impact gun or a long breaker bar?
you may have to pin the flywheel or have someone hold a pry bar in the flywheel ring gear
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dieselherb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 7:51pm
Tried a 2 ft breaker bar with a 4 ft piece of pipe, nothing bar fleece. Haven't tried impact yet
This page was generated in 1.016 seconds.
