What is the proper cap for the WD's oil sump?
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Topic: What is the proper cap for the WD's oil sump?
    Posted: 19 Apr 2020 at 7:11pm
Not even sure I have the right name or part here... On one of my WDs, there's like an orange plastic cap on it.
On the other WD, the one I think is correct, there's a metal piece with a tab on top.
What is this piece called and what is the correct original?
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 7:36pm
The first cap is from a wd 45.
Not sure what the second one is.
My w dhad a much taller cap. Sorry I don’t have a picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 7:41pm
Top picture is correct for 1952 and newer with factory battery ignition. 1/4 turn twist releases or locks it. Second picture works the same but is aftermarket, not Allis-Chalmers. If you have a magneto, it is a push on breather type cap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 7:43pm
Hot dang, interesting. They're both '53 WDs (curved shifters but not -45s). I will probably leave both as is then!
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 3:00pm
Surprised nobody gave me any grief about my Deutz oil filter, haha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 6:23am
The second picture looks like the hydraulic fill cap that has a dipstick on it. Maybe it was the same cap, just without the dipstick?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 6:41am
I was about to tell ya 6 quarts Wink
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 6:53am
GG,
 On the lower picture you can tell this is a tractor built at the transition to the 45's since the mount for the sterring is a stamping not a casting like most WD's. Both curved shifters. Wow I have never seen one of those yet. So are the features inside the transmission the same as the WD45? I would assume so. Seems kind of rare and you have two! Awesome!
Yea the top picture is a 45 type cap for the oil. Bottom one is not anything I have seen. But does reminds me of the hydraulics dipstick cover only bigger, Is that the plastic one? My guess its on the same tractor as the gas can lit brazed to the front wheel hub?????:)
We just need more pictures!
Edited by Sugarmaker - 21 Apr 2020 at 6:54am
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 7:42am
There were about 19,000 WD’s made with the newer transmission, going by memory. Not particularly rare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 10:39am
Thanks that is a lot of them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 1:00am
I can't remember offhand but the SNs on these are about 6000 apart. Can't remember which one is newer or older at the minute though, but I'll double check next time I am out there!
Sugarmaker -- I thought the top orange one was plastic, but now I'm wondered if it's stamped sheet metal and I should pay better attention. The one with the tab on it, I don't recall having a dipstick on it (like the hydraulic fluid one). Will take them both off and double check next time I go out to make sure I am right on all points! Smile
Edited by garden_guy - 22 Apr 2020 at 1:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 7:48am
GG,
 Its not plastic, I believe it is a zinc die casting, if I remember correct?? Some one will remind us of the material of the cap in picture #1.
More pictures needed too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 9:59pm
I could see that. Not sure why I thought it was plastic, I probably just tapped on it. Will try to get some good pics of both for a reference this weekend. Gotta go check my game cam and see what my friendly groundhog is up to!
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 9:04am
So I double checked and they are both definitely metal tops. Here is the underside of the one with the "tab" on it.
devron30 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote devron30 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2023 at 11:47am
What even is the part and what is it used for on the top picture. I have a wd45 and was wondering lol
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2023 at 3:29pm
That is the oil filler cap, where you pour the oil into the engine.
This page was generated in 0.101 seconds.
