Some nos stuff fs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Some nos stuff fs
    Posted: 18 Apr 2020 at 11:16pm
Hi everyone
Have some parts for sale.
-516610 bolts that fit forage harvester, 780 they bolt the knives in place.
-516611 nuts
-519095 lower or 512553 fit forage harvester, 780. Feed roll arm. Might have bearings that go in this.
-519097 upper
-225119 seal fits CA steering arm.
-4501050 studs fit A,R,D15D,D17D,D19,WD45D,HD3,2CP
-4042704 dist, cap fits 2CP,A,R,C,D19
-314078. HTP-216 jointer and frog fits plows.
-HTP-212
-314262 clamp fitting row crop cultivators.
-511575 chain fits side delivery rake, roto baler.
-800619 or 316430 master lift arm, RH fits G
-800620 or 316431 master lift arm, LH fits G
-800617 collar fits the above arm
-901270 set screw fits above collar
-226625 pulley, front crank pulley fits WC,WD,WD45 used on tractors with adj. front axles or single wheel.
-507226 bearing fits 60,60A,60H,66,72,2E,2A,150P,170P,116,4C,FH,FB,SDR,RB,110,1RCH,2RCH,66,CHD,90CHD,780,1RCP,2RCP,GSA,60SA,90SA,100SA,100SP,122,801,802
-571108 or 336670 or 345726 fits a bunch of drill planters, unit type planters.
Let me know if any interest.
Thanks
Edited by Mikez - 18 Apr 2020 at 11:19pm
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:10am
Is the 225119 the seal for the gearbox and if so will it work on a 1953 and what do you want for it? (I have a small leak on my steering box and I believe this is the seal that would need to be replaced to stop the leak?)
Thanks Matt 👍
jollymon68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 9:16am
how much for the manifold studs for the d15d, part number 4501050.
WisconsinElkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WisconsinElkman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 9:26am
How much are you asking for the pulley 226625?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2020 at 7:30pm
Bump
This page was generated in 0.287 seconds.
