Pipe fitting
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: Pipe fitting
    Posted: 18 Apr 2020 at 9:33pm
A little different question.
I need to use a 1 x 1 x 1/2" Tee sweat solder copper fitting in a rather close/tight place, and would like to know what the over all length and hight measurements are, before I go and get one. After the Stay At Home is lifted.
Thanks,
Dusty
Trawler II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trawler II Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 10:20pm
Thanks,
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trawler II Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 10:22pm
Might try Mueller Co. they make copper fittings. Should be able to see a cut sheet with takeoffs for this fitting.
Look up Mueller Streamline on the web.
Edited by Trawler II - 18 Apr 2020 at 10:24pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 10:48pm
Might google to see if they make a sharks tooth fitting like you need.  Quicker and easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 5:30am
I think its called a sharkbite, or pex fitting...Wink
Edited by DiyDave - 19 Apr 2020 at 5:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 5:58am
NIBCO is a huge mfr of them...yet I coulden't see real dimensions but I'm thinking 3.5" long and 2.25" tall.
 I'm thinking in the plumbing world nobody needs to use tape measures as they just cut the pipe to fit..... I know the road builders up near don't know what a tape measure is for !!
I'd call NIBCO or someone who STOCKS the tee and ask them for real dimensions...
Jay
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:41am
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:47am
Lowes and Menards are wide open here in central IL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:49am
hmm 2 and 9/16"  NOT 8 and 9/16.......
it's actually shorter than I thought it would be....
I wass going to see if I had one, got sidetracked and plowed the Wife's garden in the pitter,patter.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 11:23am
There are open here too, but we are under a Stay Home, and I'm try to get this project ready to do after Stay Home is lifted, and also to save a trip.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 11:27am
Thanks Plummerscarin.
Dusty
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 3:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 4:34pm
Dusty, i was wondering about that.. STAY HOME order, but the Hardware store is open ?  How does that work ?  In Illinois we have a "stay home" unless you need essentials.. you can go to Menards or Wal Mart, etc.
weiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weiner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:54pm
I think the idiot govenor here in Michigan is pushing her luck.
Real heros wear dogtags, not capes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 9:46pm
Have relatives in OH,MN that can shop on line at big box stores and pick up at storefront
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 9:49pm
BTW, I missed the part where was asking the height of fitting.
1 7/8"
fadouacommitment View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fadouacommitment Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 7:53am
Before that, I recommend you talk to a plumber anyway. He will give you a more correct and safer answer, so you will know why you need to buy and that you will not fail. A plumber has to be good at math and knows how to create and read blueprints, so I'm sure he'll give you the best advice and help. In general, you could also ask him about pipe fitting so as not to fail. It's worth asking for advice. I hope my recommendation was helpful to you.
Edited by fadouacommitment - 20 Jul 2022 at 6:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 8:00am
SPAM SPAM SPAM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 8:23am
SPAM SPAM SPAM
 Where ?
 It was long enough ago that I don't remember any of this or what I was doing, so I must have got it all done.
 This 80+ years and my memory is slipping.
  Thanks,
  Dusty
This page was generated in 0.199 seconds.
