D15 2 carb question
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Topic: D15 2 carb question
    Posted: 18 Apr 2020 at 8:24pm
Been forever since I was here!
Went out today and gas was trick'lin outta my carb!!
I need a re-build kit, and it's my thought there were a couple different carbs on these tractors. without tearin the damn thing off, can someone tell me which (what) carb I'm spose to have??? I'd take a pic of it, but it looks kinda like a ball of grease!!!!
Thanks in advance
Copyrite-
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 8:35pm
Only one on a true series 2 D-15. Marvel Schebler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 9:40pm
Thanks for the reply Doc!
Been pokin' around, found Marvel Schebler rebuild kits, the all refer to a "TSX" #, how do I figure out which one I have? Is it stamped on the carb? Dum questions, but need to get up and going, and don't want to waste time with the wrong kit!!!
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 5:21am
IIRR, tsx 869.  On a little tag, top of carb, under where it bolts to the manifold...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:57am
As Dave said, riveted at the throat of the Carburetor for large bore. On the side of the float bowl on a small bore. About the size of a dime.  A TSX 869 is a large bore Marvel that would come on like a D17. I don't think D15's had a large bore Marvel on em'. I think it should be a small bore version. Maybe like a TSX 486, or a 670. Somethin' like that.  We have Carb kits in stock if ya need help or if yer' interested...
Steve@B&B
bb-customcircuits.com
Edited by Steve in NJ - 19 Apr 2020 at 8:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 9:18am
D-15 series 2 carb is essentially the same as a D-17 except for the throttle shaft. My notes say TSX 869 or TSX 863.
Edited by DrAllis - 19 Apr 2020 at 9:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 10:30am
Thanks Fellers! Guess I got to go do some clean'in, and find that tag!
D15 Series II
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 10:39am
On my series 1 D 15 the carb tag is on the back of the carb right above the breather hose facing the seat . Mine's TSX-815 by the way , which Steve rebuilt for me . HTH
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 10:48am
Could be only float valve needs cleaning.
Jk chalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 1:07pm
Tsx 869 Are on both of my 15 series twos
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:02pm
Rebuilt mine last winter, 869 but it was tagless!
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:10pm
Well what'da ya' know! Under all that grease was a perty brass tag rivited to the throat of the carb! Got me a TSX-869!
Anyone done a thread on re-buildin' one? Smile
Thanks for all the help!
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:33pm
I’ve had pretty good luck with just getting the gaskets and giving it a thorough cleaning
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 10:09pm
So I set about to rebuild my carb, cleaned it up, tore it down, put it back together with a kit from Steve (great kit, good price, got here quick, Thanks a bunch!) I'm havin trouble with the power valve. I'm missing the packing, or don't know what it is/looks like (NOT STEVE'S FAULT!!!!). Any help would be apreciated!
D15 Series II
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:36am
copyrite1972 - see posts from today on my TSX 464 Rebuild thread - saw your question there first!
Edited by Dave(inMA) - 26 May 2020 at 9:37am
WC, CA, D14, WD45
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 10:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 10:14am
Yea, got a bit impatient, and posted in two threads...... Wacko
D15 Series II
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 10:32am
Could be the float is not floating so well, that could be due to a hole in the float or
the float has been crushed, and has lost displacement. Usually crush is caused by using
high pressure air into the fuel inlet in attempt to blow through a suspected piece of dirt.
On a historical note, the needle valve,seat and float was actually the unwritten 11th plague in the bible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 12:21pm
Brian - that's pretty funny!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 10:04pm
I am beginning to understand why.........
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 9:59pm
So, got the carb put back together, and she ran great! YAY ME! Shut'r down, and gas started pouring out of the choke rod hole...... Ok, float is bad/needs adjusted. Turned the gas off, problem solved for now. Ran her 3 more times, gas on, runs great, shut gas off. Tried running her a forth time, gas on, she won't start unless the choke is all the way on. Runs GREAT, throttle up, throttle down, just the choke HAS to be on........
Help?
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 4:42am
Re running with the choke on, either lean adjusted main screw, or air leaking bast bad felt packing(s) on choke shaft...Wink
