65' 190XT Help
whizone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Topic: 65' 190XT Help
    Posted: 18 Apr 2020 at 4:50pm
I have 65' 190XT 3 with the D2900 engine less turbo. From what I can tell the turbo was completely removed and exhaust just straight piped up.  My concern is how much HP will I have less the turbo and will the tractor perform well without it?   Also, if anyone can fill me in on how the oil pressure gauge works and where its located I would be grateful. Further if anyone has an oil gauge and assembly laying around I would be interested in it. Thanks.
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 5:00pm
I'd think it wouldn't run very good at all. No boost no power, smoke etc.  Not an expert but I think the non turbo 301s are 70-85 hp max at the flywheel depending on setup.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 6:23pm
It's pretty much a straight 190 which was 77 PTO HP. Probably smoke a lot unless the injection pump has been turned down.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 7:29pm
Not something you want to try doing serious work with! ---A pooch for sure!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 8:32pm
There is no oil pressure gauge on these tractors.  They use a red low pressure light on the dash.  The sensor is behind the fuel filter on the right side of the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2020 at 9:28pm
you can plumb a mechanical gauge to the block easily.  beware white/clear plastic lines...short lived
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:59am
Use copper tubing , not the plastic stuff, they run good and not a pooch- as was mentioned LOL, - head shaking- match them with the right implements is the thing
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 2:14pm
Thanks everyone for the input you guys are great!  Would it be worth the cost of putting a tubo on it as I'm only going to pull my 15' batwing with it on 40 acres?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 2:34pm
No not all , that engine will handle it fine, some of these respones are rediculous,,
Edited by DougG - 19 Apr 2020 at 3:37pm
This page was generated in 0.219 seconds.
