Looking for hd6b crawler rear 6 spline axle
Jeepguru04 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeepguru04 Quote  Post ReplyReply Direct Link To This Post Topic: Looking for hd6b crawler rear 6 spline axle
    Posted: 12 Apr 2020 at 12:47pm
Looking for 6 spline axle and rear spherical roller bearing
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 8:14pm
i saw on another post Coke had one. wait for him to reply, if not I will check stock. where are you located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeepguru04 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 1:36am
Burbank ohio
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 9:53am
Somewhere around here i should have one but can't remember where i hid it .
If you can't find one local will see if I can hunt it up .
that outboard link belt bearing is a hard one to find as it consists of a roller bearing with barrel type rollers in tandem
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 11:20am
Biggest issue will be seals, NLA Unobtanium.
This page was generated in 0.035 seconds.
