Tire swap, Allis to Jubilee?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Topic: Tire swap, Allis to Jubilee?
    Posted: 11 Apr 2020 at 9:12pm
Folks,
 I have a extra set of tires. Really good Firestone Field and Road 13.6-28's that are still on rims and centers from my Allis WZ project tractor. I am considering having them unmounted from the Allis rims and mounted on the Ford Jubilee. It has the 12.4-28's on it now and they have a lot of tread but the side walls are very cracked. Those are Titan brand. They had some cracks 6 years ago when I got the tractor which had been restored 7 years prior to that. So they have a lot of age and not much actual work.
The 13.6's are going to be 4 inches taller, but should go right on the Ford rims which are in very good shape (new rims and centers when it was restored). Anyone see any big disadvantage in doing this swap?
The Firestones:
Just a little dirty:
The Titians on the Jubilee now:
Yes the chains may not fit, May have to add some links and a cross chain?
Speed of tractor may be off? May not be able to take it in antique tractor pulls due to over size tires? Might have to move the fenders a little??
Humm, another toy project! Might keep me busy for a couple days! I cant really think of a down side.:) And no rim work!
Edited by Sugarmaker - 11 Apr 2020 at 9:19pm
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 9:37pm
 Well Chris,,,if you change your mind,,,shall I send you my address,,?? Wink
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 4:56am
I can't tell from looking at the pictures, but I will say this; tractor wheel bolt-patterns are pretty much standard; measure the bolt-patterns and you might be lucky enough that the wheels will bolt right on.
If not, another option that is way better than swapping tires around from rim to rim is to make some wheel adapters that will allow the bigger tires to bolt on.
Besides the money and aggravation savings compared to dismounting four and mounting two tires, and the added aggravation if either or both happen to have fluid in them, a set of wheel adapters will allow the smaller tires to remain on the rims, ready to bolt back on whenever the need arises.
Making wheel adapters for a tractor that crawls around at twelve MPH is not so critical as making wheel adapters for a truck that may be going eighty MPH.
The previous owner made a set of simple wheel adapters that were on my 1971 Mitsubishi years ago when I bought it; I got the tractor with a brand-new set of 12.4-24 tractor treads on the adapted wheels, plus a pair of like-new 11.00 x 16 flotation turf tires/wheels that are original to the tractor.
I have never bolted on the turf tires, but they are there, aired up and ready, should the need ever arise.
I was surprised that the 11.00x16 are almost as tall as the 12.4-24.
All of that being said, the wheels just might have the same bolt-pattern and the swap be simple.
Edited by BuckSkin - 12 Apr 2020 at 4:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 5:06am
As best I can tell from the picture of the Ford, it would be a very simple matter to make a pair of adapters should they be necessary.
Cut a circular piece of 3/4" or so plate.
Scribe and drill sixteen holes; eight holes to bolt on the Ford and eight holes spaced between them for studs to mount the Allis wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 7:35am
The Jubilee bolt pattern is smaller that the Allis. You'll be suprised how much taller the 13.6 tires are over the 12.4 ones. Then you be looking for a power upgrade for the Ford as it will seem to die.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 8:48am
Thanks guys,
My thought was not to mount the Allis spin outs on the Ford. That just doesnt seem right!:) I was going to remove all four tires from the rims and put the 13.6's on the Jubilee rims. Might cost me a little bit of jing, but also seems like the "right" thing to do!
I forgot to mention that I dont change any of these myself I have enough issues getting them to the tire shop and back.
 Paul,
I dont really plan to pull this tractor. Although I have done that in the past just to donate some dollars to the events! I have enough AC's to haul around for that too. This little Ford has never done well in antique pulls anyway. It stays home and does the chores most of the time. Do you think I would notice any difference in just normal things like brush hogging? I wouldn't think it would make much difference there?
I hate to let this good set of tires go down the road and then realize I could have used them. I would rather let those Titans go to someone who might need to get a tractor back up on its feet.
Another part of this would be to clean up the Allis rims, centers, and eccentrics, and have them set aside for another potential project!:)
Edited by Sugarmaker - 12 Apr 2020 at 8:50am
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 9:57am
As long as you brush hog flat ground you should be fine. More power to turn the wheels leaves less to turn the hog.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 2:05pm
We went one size over stock when I replaced the rear tires on our 8N ford, I liked how that turned out faster ground speed better traction. The tires clear the fender ok  but not as much room in between dirt sticking on the tires hits your hand if you are holding the fender. Depends on how you are set up to get just a little more clearance you could mess with wheel spacing bolt the rims to the outside of the dish or I dont know for sure but the loops on the rims may give you more offset one way or another
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 2:33pm
Far easier to swap the tires from rim to rim rather than make adapters, unless they are full of fluid. A duck bill tire hammer, 1 pair of pliers, 2 30" bars and some good tire lube. And a good back which I ain't got anymore. Have fun with them.
Edited by HD6GTOM - 12 Apr 2020 at 2:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 3:17pm
You'll probably find that everything you do you'll be doing in a lower gear. It's surprising how fast one size bigger tire is doing field work, especially mowing. Engineers did a lot of figuring for gear ratios to match with tire sizes. I've seen Fords that would pull a plow just fine until they got a new bigger set of tires, then they were almost worthless. #1 they were travelling a half gear faster, #2 with good tread they weren't slipping as much.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 8:43am
A little taller tire will mean your bush hog will be a little higher off the ground until you lower your 3 point arms.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 11:26am
Thanks guys,
 My plan is to get these changed over and try the larger ones on the Ford in the near future. i will let you know how this works out. Specs say 10-28 for the Jubilee, so these will be 2 sizes larger.
I can use the D17 on the brush hog now too, since I have the three point set up on it now.
And for plowing I have the WD45 with the three bottom 14's. So I am pretty well covered!:)
We have high wind today. Tried to get slab wood but the sawmill was not working. Might go monkey with this tire project if I get to feeling ambitious which doesn't happen much any more!
Edited by Sugarmaker - 13 Apr 2020 at 11:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 12:02pm
The implement dealer in our town sells generic rims for about fifty bucks apiece; we have used hundreds of them and they fit and perform as good as originals.
Were it me, if adapters were out of the question, I would leave the current Ford tires mounted and buy a second pair of rims for the bigger tires.
I have played this game all of my life and have learned the hard way what to expect.
Off of the rims, any prospective buyers of the smaller tires are going to be skeptical; most people will pay more for tires that are mounted and obviously holding air, even if they are on the wrong rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 6:36pm
Buckskin,
 Thanks for your comments. Good thoughts on tires on or off the rims for resale too.
The right thing is usually not what I do. But I continue to try to fall forward!:)
The Allis rims loaded:
Centers knocked out, Another project If I feel like cleaning these up and getting the eccentrics freed up too:
The older Titans loaded:
Will see how this goes: Forgot I need to get these changed or I might have to buzz wood with the D17:
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 8:22pm
i think i would have just keept running those titans until there was a problem they could do feild work for quite awhile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 9:52pm
Looks like if you need a few inches of clearance for the new tires you can bolt the rims to the front side of the dish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 6:09am
well, with my luck, I'd have to make some fender spacers, to raise them up 3" and only have 2" steel in the scrapbin.......weld up a 'Z' using to 'L's, drill holes and then find out the spacing's wrong...... failing forward......sigh...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 2:22pm
Yeah, I like that idea of buying 2 other rims.  I still wrassle with changing tires yet, but I'm getting too old to do that anymore.  But then, it keeps me strong and feeling young.
I'll bet Eldon can give some tips on changing them, it's kind of his specialty.
If the eccentrics are really stuck and rusted bad, just throw them in your fire box and fish em out the next day.  Oh yeah, make sure you take the eccentric pin blocks out first, or you'll have to fish through the ashes.  I've been doing this ever since I learned of it and it works wonderfully EVERY time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 3:08pm
Folks,
Hoping these larger tires slip right on there with no issue!
As usual my day doesn't turn out like expected or planned. Took the tires to the shop They thought they would have them done today. Grandson Mike called and we went and got a used lawn mower on the trailer. Took his two front tires to the tire shop to get tubes put in. Dropped the lawn tractor at his place. Headed over to get slabs and the loader was down due to brake issues. Back home with not much accomplished and no tires!:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 3:49pm
I agree; although all of those cracks don't look very pretty, it would probably be another thirty years before the inner-tubes started showing through.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 6:35pm
Guys,
 I agree I believe those Titans would have worked for a long time too! Just another project to keep a guy busy. Should make the Ford look better at the auction too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 2:59pm
Folks,
Finished up this little tire project this morning.
Looks like it should work out Ok with the Firestone 13.6-28's on it!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 5:06pm
Those look good on there
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 6:50pm
agreed... ... don't even look too big
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 8:49pm
Chris,Those 13.6's look great on the jubiliee..Good call on the change..Thumbs UpThumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 11:23am
Thanks guys,
I got home from the tire shop with all the tires, rims and new mounted tires. The right rear was the last one to take off the trailer. I went to lift it up, and it felt soft, no air in it. Looked and there was no cap on the valve stem. Thought they must have just forgot to add air after setting the bead.
 Rolled it off, mounted it on the Ford and added air. Which immediately came out around the valve stem. This was one he told me they put the old tube in. Back off the tractor, back on the trailer, and back to the shop, for a new tube. After that things worked better and I took a nap!
Probably the best pair of spin out rims I have brought home. Not a matched set but still in good shape.
Here is what it looked like out back today. Hunkered down for winter again I guess!:)
Yea these 13.6x 28's don't look out of place at all on the little off color tractor.
Edited by Sugarmaker - 16 Apr 2020 at 11:24am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 1:27pm
Yes there sure look good on there and she sets level.
This page was generated in 0.234 seconds.
