allis chalmers hd 16 ac torque converter seal |
lunchbox06
Topic: allis chalmers hd 16 ac torque converter sealPosted: 07 Apr 2020 at 10:36pm |
i have a hd 16 ac serial number 1068 and im pouring fuel out of my torque converter. anyone know how to change that seal? do i have to pull the whole converter or can i just take the rear plate off to get to the seal. also does anyone know where i might be able to find the part to replace the seal. i have the part number if it helps just let me know. any help would be great thanks.
Edited by lunchbox06 - 07 Apr 2020 at 10:37pm |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 08 Apr 2020 at 7:14am |
go to http://minnpar.com and put in your seal #.
you can also try the oem seal makers. the first link is for AC parts supplier. the second 2 are SKF and National seals cross # and most AC numbers will cross on 1 or the other. if it doesnt come up with these 3, you will have to try to match up by dimensions. I have had pretty good luck coming up with seals and bearings this way even back to 1937 UC tractor. EDIT> just looked at my HD20 parts book and the output seal is a multipiece job.. soo this route may not work if its the same on a 16 unless minnpar happens to have the KIT. Edited by CAL(KS) - 08 Apr 2020 at 7:28am |
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
lunchbox06
Posted: 08 Apr 2020 at 8:21am |
Do you know if to change that I'm going to have to put the whole converter to change it or can I just pull the back cover plate and change it that way. Also would the front seal and real seal be the same or different?
CAL(KS)
Posted: 08 Apr 2020 at 9:37am |
i have no idea. my 16 is direct drive and HD20 is new to me. hopefully never have to mess with a converter.
