NOT a Ford problem.... |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Topic: NOT a Ford problem....Posted: 07 Apr 2020 at 8:20am |
Ok, so neighbour starts his GMC pickup from storing over winter....starts easy, runs good, warms up,blablabla.... turns key off, key in hand, truck is STILL running !! Disconnects battery... STILL running !!!! So.. anyone know WHY ?? I do.....
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90804 |
Posted: 07 Apr 2020 at 8:23am |
must be running off the alternator ? Something shorted or STUCK in wire circuit ?
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 07 Apr 2020 at 11:23am |
Didn't they use a diode or idiot light for that problem on old GM's?
jaybmiller
Posted: 07 Apr 2020 at 3:58pm |
2011 GMC... yeah Alternator must have a diode shorted , so it's powering the engine. If, IF, it'd be a stick shift stopping would have been a lot easier.... got another donor truck today, one with that idiotic engine in it that burns more oil than gas..will swap alternators....
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 09 Apr 2020 at 12:44am |
Probably stuck contacts in the ignition switch. Ignition switches were not unusual on that style truck. It's nothing for the alternator to power everything at idle. The thing to do would be check for power moding DTCs in the body control and ECM.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 09 Apr 2020 at 6:54am |
But, "Disconnected battery and still running". ?
fixer1958
Posted: 09 Apr 2020 at 7:28am |
Seems it would have a substantial battery drain if either were the case. Any aftermarket stuff on it?
BuckSkin
Joined: 12 Sep 2019 Location: Poor Farm Points: 1165 |
Posted: 09 Apr 2020 at 1:15pm |
You didn't specify whether it was gasoline or diesel.
It is common on diesels with an electrical shut-off to have the tip get worn on the little rubber shut-off plunger and run with the battery dis-connected. |
jaybmiller
Posted: 09 Apr 2020 at 2:43pm |
run of the mill ,basic gas ( 4.? or 5.??) engine, no aftermarket stuff. start it up, yank off battery , take key out... still runs. disconnect big alt wire...it dies... now I'm wondering about the key, since it's fuel injected/ electric fuel pump...just how does anFI engine run without power to injectors ????? hmmmm, sounds more like the switch.... will have to wait as the 'machine' dumped some wet white here this morning..... and I'm onto other projects...
BuckSkin
Posted: 09 Apr 2020 at 4:35pm |
Years ago, the wife had a Chevrolet Corsica (not a wise choice of transportation even when new); one night, she came in and announced "my car won't turn off".
I went out and, sure enough, it would not shut off. It being an automatic (another poor choice), I began scratching my head as to how to kill the engine; then, I happened to remember that, if you came to a stop with the A/C running, it would die. I flipped on the A/C and the engine immediately died. The problem on that one was a key-switch gone bad. |
fixer1958
Posted: 10 Apr 2020 at 5:37am |
Might have a relay staying energized with the key off. Some have key off power. Have to be grounded to work. Something has to keep the PCM alive if it still runs. If it does it again pull a relay in the fuse box under the hood on the left front. Should be marked on the lid. PWR/TRN something like that. |
