For Sale: 20-35 project
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Topic: For Sale: 20-35 project
    Posted: 05 Apr 2020 at 7:32pm
I have a 1928 20-35 model E that I decided to sell. IT is a good project tractor. It is serial number 13774. It went through a shed fire. It faired ok as it didn't melt the radiator core or the carburetor. IT looked way better than the JD'S that where sitting next to it. It probably will need new Babbitt on the rod bearings as the heat from the ash started to melt them. The crank turns nice so the main bearing should be ok. There was still oil in the engine before we took the pan off. The front axle and steering cover are in good condition. These are normally worn & broke due to field use. I believe this tractor was mainly used for belt work. I had the air cleaner casting repaired and do have all the parts for it. I also acquired a few new parts for it and nice original fenders and 5" gas pistons that go with the tractor. I'm asking $1750.00 It is located in Jordan, MN. I'm 52 miles from Hutchinson so you could pick it up during the Orange Spectacular. Send me a PM if you have any interest in it. Thanks Matt
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 12:14pm
It needs a new home. Price reduced to $1500. If it doesn’t sell I will consider selling parts off it
farmboycitygirl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 7:51pm
wondering if you still have this 20-35?
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 7:12am
I sent you a pm about this tractor
Jsmittyd10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jsmittyd10 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 10:27pm
Do you still have the 20-35? Call me 405-627-7305
Absolutely love Allis Chalmers tractors
D17 s4, D10 s3, D15 s2, 720, D17 forklift, 6080 2wd with cab, I40 backhoe, d12 industrial with backhoe and loader
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2020 at 5:34pm
I have it what are you looking for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 9:19pm
Just got 2 more 20-35s in one for parts and one mostly complete
