Hydraulic lift
Natew15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natew15 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic lift
    Posted: 05 Apr 2020 at 11:49am
I have a 1953 WD that has a drop bucket that only rises. When the clutch is released, the bucket goes up until its maxed out. The valve was recently rebuilt to try and solve the issue. Fluid is full, rams are operational and all the linkages are hooked up. Been reading though a service manual but all it says is the hold valve is the problem. Any ideas? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:25pm
The hydraulic pump only works when the foot clutch is released on a WD45.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 11:25pm
Put the tractor in neutral, running and try the lever.  Does the bucket go up and down?
Are you using the lever on the left side of the steering wheel?  Up to the top makes the bucket go up and down to horizontal makes it go down.  Moving the lever slowly makes the bucket and the rear lift arms go slowly.  With the lever in the middle position, it should lock (hold) the bucket and arms in that position until you either raise or lower the lever.  I hope this is clear for you and not as clear as mud for you.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 6:07am
When you say the valve was rebuilt, do you mean you pulled the pump off the tractor and went through it? Or is it a remote valve that is not original to the tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natew15 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 11:36am
When the clutch is released, the bucket only goes up will not lower or hold with the left lever full down. The left lever connects to the hold valve which is what was rebuilt. I'd post pics but they're too big to post. I pulled the pump off after posting to find one of the lobes broke (the spinning part). I assume this would cause the issue? Thabks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natew15 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 11:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natew15 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 11:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 11:51am
Your pump has ingested some of the iron, sticking the control spools. A massive job of cleaning the oil cavity and throwing a cow magnet inside is in order.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natew15 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 1:54pm
Any advice on where to find parts and what to use to clean and replace the fluid with? I'm seeing that SAE 20 oil is recommended.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 7:23pm
There are adjustments to the controls on the pump. One setting is for a mounted plow with Traction Booster, which does not have a hold position, the other has a hold position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 9:04pm
Your local Agco dealer should have the parts. Find the roller assembly at a salvage yard. They are pricey at Agco dealer.       MACK
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 10:04pm
P M sent
Albert
