37WC Steering shaft U-joint
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Topic: 37WC Steering shaft U-joint
    Posted: 03 Apr 2020 at 8:48pm
My WC steering U joint appears to be a permanent sealed  type with no grease fitting.  No snap rings.   It is in good shape except for the pin bore to the worm gear shaft was allowed to get sloppy and wore the hole out.  I think it had already been drilled oversize.
They are in the $100 range to but complete from aftermarket suppliers .  I was thinking about trying to disassemble and fill the pin hole with lead or brass and redrill.   The big worm shaft bore was not too bad.  Replacing the old style pins with roll pins like the newer tractors.
I suspect this is not the original yoke bearings for a 1937 tractor, the bearings just seem to be too good compared to other wear parts.   DJs Tractor shows a rebuild kit for less than $20 but not sure how universal they fit.  Most of the pictures show a snap ring style yokes  with grease fitting in the cross if it is rebuildable style.   I may be able to get it apart without ruining the seals, may try that before I order a new U joint.
It is easy to work on this now because the engine is still on the floor.  Looks like access is not very easy after the engine is back in place.  Good news was that since it had been moving around a bit, it was easy to slide apart when I pulled the engine.  Even getting off the steering shaft was not too bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 9:15am
Got it cleaned up better this morning now I see this type had retaining rings on the inside of the yoke.  Groove in the cups.   I will probably pull apart and try to reuse everything.
As far as I can tell the old books did not call out any maintenance on these joints so they must be pretty good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 9:19am
I am guessing but this appears to be the correct repair kit for it.
https://stores.djstractorparts.com/steering-shaft-cross-and-bearing-u-joint-ab-2507d/
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 7:59pm
On the WC steering U-joint the problem we had with them was not in the Joint but in the steering shaft itself.  The holes in the shaft would wear egg shaped.  To correct the problem - remember this is in the 30's money was TIGHT - we would over drill the hole in the joint and the shaft to make them round again.  Put in the right size bolt and it worked for a while.
I drove one about 6 miles home with a wobbly front wheel.  Was a challenging trip.
Good Luck!
Bill Long
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 3:33am
Back in the 60's Dad bought an unstyled WC w/ cultivators at auction for $130. All good except steering so bad you couldn't keep it on the corn row. Still better than running a JD A with hand lift cultivators.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 6:16am
As far into it as you are and your effort to do a good job I suggest removing shaft from steering box and weld hole shut, then do the same with u-joint, redrill 3/8 inch and use roll pin.    A machine shop or someone with a milling machine can drill the holes on center for you.    Do not use lead to fill holes it will only last about 5 min.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 8:24am
If you go back together with bolts instead of pins, be sure to give the wheel a couple of spins to be sure either end of the bolt doesn’t hit the frame before you call it good. It doesn’t hurt to run a safety wire through the pin if you’re gonna use a roll pin, not something you want to have fall out while you’re driving along
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:01am
I Use Double Roll Pins
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:34am
When I repaired my governor shaft I used a roll pin as you say, drilled the hole just slightly larger.   I did not safety wire that one but seemed plenty tight.
I have a new worm shaft being made as it was worn pretty bad in same areas and not worth saving.  I will try the welding shut trick as you suggest on the yoke that was egged out.   I did that on a throttle lever and was surprised how well it worked.
I suspect this tractor will have an easy life.  Not familiar with double roll pins,  think it needs more than a standard pin?   I thought the later tractors like the WD switched to a roll pin so figured that would be strong enough.  Thought about using some loctite or Devcon on the worm gear just to make double sure.
Edited by Rick of HopeIN - 05 Apr 2020 at 9:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:39am
Put One Pin Inside The Other One
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:43am
Ah Thanks!
68mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68mustang Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 7:45pm
Hi rick , need help with my steering, the shaft worm has wobble inside the shaft support , does that mean the shaft is bent?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 11:30am
I have a couple of these NOS sector gear for the W_ tractors available. Sorry I don't have the matching worm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 7:38am
Could be bad roller bearings. My worm is a sliding fit on the shaft but seems OK once the bearings pull together. Thankfully that was one part that does not seem to be worn. I am guessing a good shop could salvage the worm itself but may get pricy. If the big bore inside the worm itself is worn probably better to get he part number and watch for one to come up on Ebay, etc.   My worm gear seems hard so I am guessing the shaft would tend to wear first.
This page was generated in 0.273 seconds.
