180 Gasser ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: 180 Gasser ??
    Posted: 03 Apr 2020 at 8:23pm
According to tractor data, there were roughly 10,500 180's made. Only 1,100'ish were gassers, does that make ours a "collectors'" model Smile Wink ??
Edited by FREEDGUY - 03 Apr 2020 at 8:23pm
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 7:28pm
The neighbors without 3pt is gas, know of a couple others, 1 diesel and 1 gas but both with 3pt.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 7:33pm
I have two 180 gas tractors...had three, but sold one. I have one with 2800 original hours on it...1969 model...
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 8:41pm
I have a 180 gas and know of another.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 9:14pm
The gas 180's usually bring less money than a diesel one.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 11:25am
How do the newer larger AC 6 cylinder gas engines run? Do they have any issues? The good 226 4 cylinder engine was the only AC gas I’ve ever operated in the D17 /One-Seventy tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 12:28pm
301 gas engine in a 190XT was famous for breaking piston tops off of the skirt. A-C never resolved the problem. I think when you need to overhaul a 265 or 301 gas engine, there are no repair parts (pistons/sleeves) available anymore. They ran like everyone else's big gassers at that time: cold-blooded and use lots of fuel.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 12:32pm
I often wonder how well these would run with the EFI conversion that Dave Kepner is doing to 3020/4020's. He isn't doing any other makes of tractors that I'm aware of, but that would be a nice upgrade. I'm a diesel guy though lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 1:23pm
Traded for my 180 gas back in the early 1980's have used it for a lot of things over the years,have a loader on it now motor has never been gone into since I have had it still runs very well.For a tractor its size it doesn't  use anymore gas than any other gas tractor its size.Had a 190XT gas for awhile now that thing could soak up some gas a whole lot more than my 180 think it had a 301 in it.
Lonn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 2:25pm
I thought Allis came out with a stronger piston for those engines. I remember a 190XT in the shop that had a broken piston but I don't remember if we overhauled it completely or just replaced that piston. It's been almost 30 years ago.
My Dad's 190XT would always start in the cold Minnesota winters and it always liked gasoline no matter what the job.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 5:00pm
I was just surprised by the 10-1 ratio Smile. Were there any 185 gassers produced ?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 5:11pm
No
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 5:41pm
180 and 190 were 265 cubic inches. 180 had a smaller carburetor than a 190. 190XT was 301 cubes and had a larger carb than a 190.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 7:50pm
Got a 190 gasser and it sounds just like an ole Gleaner engine ,, works great tho,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 8:22pm
Only an early model "G" Gleaner ever used a G-301 gas engine and a G-265 was never in any Gleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 8:45pm
A 190xt gas would not use any more gas than a D19 gas.       MACK
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:47pm
265 cylinder parts are NLA. Rings are the only thing available.
Rebuilding a 301 gas right now. Reliance and Mahle/Clevite have most the parts Available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 7:46am
I had both at the same time the 190XT burned a whole lot more gas than the 180,of course the 190XT had a whole lot more power.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 11:14am
I don't see why that should be surprising.  Just look at the history of farm tractors and the time frame you're talking about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 5:20pm
Stern Smile , any idea of  when/model of the LAST gas engine was offered?? You might surprise me by your answer Wink.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 8:41pm
I'd guess for the 180 1973 and I'm pretty sure for all Allis Chalmers farm tractors, the 175 in 1976.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 5:04pm
Thanks Lonn  Smile
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 5:19pm
My buddy sold his 180 gas a couple years ago----he despised it---controls were all over and you had to reach for everything on them---nuttin handy bout them.  He took the money from the 180 and put it on a 200 ,--- so now he has the 200, a 190 xtd, and a 190 gas. He loves the controls on them.
I always found the 190's a better tractor to drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:24pm
Your buddy would've completely freaked out running a D-19 Wink, talk about "all- over- the-place" controls Confused
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:33pm
I would never say I hated a 180 because of the control layout. Yes a 190 or 200 is better but the 180 is no worse than a 3020, 4020, 656, 1650, M670, 5000 etc. They all have levers in all directions and some in harder to reach spots. In my biased book the 180 wins. Big smile
Edited by Lonn - 09 Apr 2020 at 7:35pm
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:37pm
Growing up running the D series I never gave the control positions much thought. Beat the neighbor's 560 to pieces IMO............. Looks like I'll always go to bat for AC!
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:41pm
I also ran a 560 IH for a neighbor, but for the life of me, I can't recall the hydraulic lever layout Ermm. I DO recall the '19's configuration Ouch.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:51pm
If I remember right the 560 was at the right and slightly to the rear of the seat while the D19 was just on the left side of the seat. I always liked running my D19 because it was quiet, had a long wheelbase for a gentle ride and it had two way hydraulics vs the old D17. The D19 would walk through mud better than Dad's 190XT even with the narrow 7.50x16 fronts vs the XT with 10.00x16 fronts.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:57pm
I was wrong, the hydraulic levers are to the right of the steering wheel on a 560. D19 wins hands down for hydraulic lever placement.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 8:32pm
Last one available isn’t the same thing as when the popularity of diesel and demise of gas began. No surprise, sorry.
