Electric Wheel Co. running gear
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Topic: Electric Wheel Co. running gear
    Posted: 03 Apr 2020 at 1:10pm
My  neighbor has an Electric Wheel Co. running gear according to the data plate.
It is orange and sure looks like the same running gear that A-C sold. I know
that Electric Wheel made many of the rims used by Allis.
  I can post a picture if that would help.
Thanks, Dean
PS,
  We are safe and warm and fed, so we feel Blessed. All of you, stay well
and God Bless you all.
Dean(IA)
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 3:58pm
Yes electric wheel manufactured multiple brands of wagon running gears throughout their years. Among the brands that they manufactured for are as follows; Allis Chalmers, Case, David Bradley(Sears),Dakon,IH, MF, New Idea, New Holland, Minneapolis Moline, Oliver, & Wards((Montgomery Wards).
Edited by AC7060IL - 03 Apr 2020 at 4:07pm
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 5:26pm
Must be they made them to the specs called for by each company. We had a couple of New Holland, and they sure appeared to be better than some of the others. Sears for one.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 5:56pm
I may be completely wrong, but I thought Badger wagons were made by Electric.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 10:31am
Here’s a great article link that discusses EWC’s beginnings. I believe Art’s Way may have also had EWC mfg their earlier running gears?
https://www.hsqac.org/company-once-had-largest-wheel-shop-in-world
Here’s another link that shows a cool older black/white photo of EWC dock workers loading rail cars & delivery trucks with wheels
http://www.idaillinois.org/cdm/ref/collection/qpl/id/1449
Edited by AC7060IL - 04 Apr 2020 at 10:32am
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 5:39pm
It really doesn't matter. Any running gear including Electric and AC with no way to grease the steering tie rods are JUNK. After just a few years of normal use they are done. I have owned them both and I'm talking from experience. After a short time of use try towing them down a highway and see how fast you get before they are all over the road.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 4:13pm
Ky.Allis, I disagree. Junk is such an absolute term. EWC’s wagon gears were built well during their 1960-1970s era. You’re correct about their non-grease zerk tie rod ends which contain either a plastic or metal wear bushing which can be disassembled, lightly greased, & reassembled using an impact wrench in about 2-3 minutes per side. Please note: The tie rod end attaching bolt threads into it’s tie-rod cast housing on 10-12 ton gears(And maybe on the 7-8 ton gears?). If maintenanced once per season, they’ll last.
I too own & operate 5 different EWC built branded gravity wagons for decades. My experience has been that the critical steering slop that you suggest results mostly where the tongue’s rear attaching pin wears itself & wears both ends where it connects to the steering center pivot.
All of mine will behave while being pulled empty behind pickup at 50mph. The worst brand seems to be the EWCs inthat their tongue/pivot assemblies resembles the older narrow David Bradley style. The New Holland & Wards assemblies are similar. They require a more snug pin to reduce slop. The AC, NI, MF, Dakon, Case, & IH generally have a wider flared rear tongue that allows more stability where it connects to its pivot.
Edited by AC7060IL - 05 Apr 2020 at 4:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 6:28pm
Your right!! If you took the time to disassemble the steering rod joints and lube them they would last longer. But greaseable ball joints have been around a very,very long time and how much more would it cost to add them to a wagon running gear to drastically increase it's life and make it so simple to hit with a grease gun a few times per year.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 7:02pm
I have drilled and tapped tie rods and ball joints on automotive stuff and installed grease zerks. Maybe some of these could be as well???? Has anyone tried? I’m not familiar with these running gears so totally guessing.
