185 value update
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 185 value update
    Posted: 02 Apr 2020 at 5:01pm
Hi everyone.
For some reason dad was going through the file drawer and looking at old customers, and made him think to call on a guy to chat. He's in his late nineties and is doing ok, in conversation he said he might want to sell his 185. So we think we should go and talk with him and look at it. I know you guys have a lot of factors for price. I don't have much info, but do know it's shed kept and does run. Last time we seen it it was a clean average tractor. But what's a good starting price to have in mind and when we're there with tractor can determine what to deduct for or maybe add if it's clean good tractor. Just figured it's one of those deals that you have to be there in person with a handshake. Hope this makes sense. Thanks for your comments.
Edited by Mikez - 06 Apr 2020 at 12:33pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 5:07pm
Rear rims and tires.  If the chloride leaked it will have ruined the rims.  Check around the valve stems for damage.  That'll drop the price.  Shape of the tin, fenders, and lights.  How the engine runs.  How many hours?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 8:10pm
Theres alot of value in a 185 yet for haying etc,,, Id start at 5000,, if its shedded, and oringinal paint ,, dont get low balled, cause theres alot of those fellas out there
Edited by DougG - 02 Apr 2020 at 8:55pm
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 8:54pm
If low hours and clean, a very nice 185 will do 10-12k in my area. Deduct for what it needs.
Edited by allisbred - 02 Apr 2020 at 8:55pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 9:58pm
When in doubt, ask the owner what he thinks it is worth and go from there.  Tell him you will give it a good home and he might go easy on the price.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 6:47am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 6:54am
Most likely has 3 pt hitch, that's a plus if it does. Minus if it doesn't. Having both PTO's is a big plus if it has that option. And hydraulic PTO clutch is another big thing to pay a little more for if it has it. Darrel
Edited by darrel in ND - 03 Apr 2020 at 6:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 7:12am
I didn’t know that a 185 was available without 3pt? I would say another bonus for 30” rubber, 28” seems less desirable.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 7:27am
I guess location makes a huge difference. In our area (northern NY State), 185's in good condition go for $3,000 - $4,000.
For me, the things I would want to check for are:
~signs of coolant in the engine oil
~excessive blow by when up to operating temperature
~rear end being over full
~transmission (gear jumper)
~hydraulics - fluid not milky, no leaks and everything works ok
~power director works as it should
~ does it have a hydraulic PTO
~tires and rims (as stated above)
Good luck !!!
Edited by WF owner - 03 Apr 2020 at 7:30am
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 7:32am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 9:18am
I bought a 185 out of an estate a few years ago,had not run for about 5 years,looked pretty good,wiring a mess,good tires all around,good rims,had a loader gave $1000 as it sat.Turns out it started up and ran good,hydraulics,power steering good,needed a muffler,
did a little rewiring and a one wire alternator,2nd gear bad.Overall a good tractor for what I
paid use it to load round hay bales.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 7:56pm
Our '69 180 has 3 point hitch and hydraulic PTO engagement (540 only), would have thought a 185 would be standard equipment ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 8:03pm
I've never seen a 180 or 185 without three point hitch.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 8:08pm
I have a neighbor with a 180 without 3pt, never seen a 185 without.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 9:39pm
Where you live bare backs are not uncommon
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 7:26pm
Yes, in this area there were lots of 190xt,s and 706 and 806 IH without three points, even a few 200. Then in the early 70s we started raising sunflowers and everyone want three point to cultivate, a lot of after market 3pts installed. I had a 706, put Cornhusker 3pt on, was fine for cultivating with a 6 row, maybe not so good for a plow or heavy tillage. Just sold that 706 this winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:56pm
Thanks guys. When you ask on here you get a wide verity of comments. And sometimes something you might forget to consider. Hope to go this week.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 12:32pm
Ok we went and looked. Not as nice as last time we seen it but still not bad. It's not all tour up. Sheet metal, fenders aren't rotted and are straight, the hood has a dent but not real bad, has side tins, grill shroud is good but screen is dented. Looks like a older repaint. Has one ag front and one truck tire on front, rear tires are descent with more then half tread and not cracked, one rim is good an one is showing rust that prolly by time it needs tires will need replacing. Tach shows 2500 hr. There's hyd lines to the pto drop box so that's hyd pto right. He hasn't used it in five years but starts it each year. Radiator is full an clean looking, oil looks ok. He told dad 5000 before we even looked, the battery didn't have enough umph to start it but did turn over. After that he told dad 4000. He getting older and hates seeing it sit. Should we go back with battery and run it or go back with battery and run it onto a trailer to bring home. Did I leave anything out.
Thanks for your input
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 2:01pm
better buy it before he changes his mind!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 2:17pm
$4k and not pay for any repairs to sell it, would already be gone. 185 should have either or 540/1000 pto, also did not state rear or front rims sizes, OE fronts should have been 15's for 9.5 15Ls, and rears could be either 4 rail 28s or five rail thirties, sure wish I could find a set of thirties and centers for my 180. ONE 18.4/28 is as much as a pair of ANY width 30's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 3:19pm
In my part of the world, he is still pretty high.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 5:13pm
Price is about right here. I'd love to have it for that price.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 6:57pm
18-4-30 rear
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 8:31pm
4k is a great price, especially when he dropped a thousand while you were looking at it.  Doesn't sound like it needs anything major, but I would get that rusty rear rim dealt with sooner as opposed to later.  Rust does not get better over time.  Dismount the tire, sandblast the inside of the rim and repair any rust holes, prime, paint and you will have one less thing to worry about.
I would jump on that tractor!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 8:32am
185 is one of the best tractors AC built. If it came down to keeping just one the 6080 would have to leave. Hope that day never gets here!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 8:40am
Neighbor has a 185, 30" rears, 16 fronts, wish I had it but my 180 does give me good service.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 8:49pm
Ok we were making plans to go back an see if can get her running. I didn't see this from where I was but dad said when he was cranking it that day the steering wheel and wheels were turning. Every time he hit starter the wheels would turn, think he said to the left. I thought that sounded odd
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 7:02am
I was thinking the same thing, never seen a 185 that did not come with 3ph but there is a first for everything, and I agree on the 30" rims, especially if you have to take it on the road.  It is amazing how much faster mine is going down the highway with 30" rims verses my neighbors with 28" rims.  Did not realize the difference until I drove his for him one day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 12:39pm
With the pump turned up and on 30’s, they will almost fly if wings were an option— lol. I ran my father’s 185 down the road last year and had to slow down to a late model JD. Later, the farmer asked me how fast that 185 would go. All I know is it’s a lot faster than mine!
Edited by allisbred - 22 Apr 2020 at 1:05pm
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 12:44pm
Yep! Now imagine a turbo’d 185 on 18.4x34’s. It has a sweet sound and I don’t know how fast it goes but it’s almost scary
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
