Copper fuel line
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Copper fuel line
    Posted: 02 Apr 2020 at 11:32am
I just bought a piece of 5/16” brake line to make a fuel line for my old truck project. It’s the line that goes from the fuel pump to the carb. I also bought a tube bender kit and it made neat work on this project. I cut the end off the brake line and noticed that it appears to be copper lines.
I’ve been told in recent years to stay away from copper on fuel lines. What do y’all say?
This brake is a dark army green color on the outside and copper inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 11:53am
from the net, 1st google search of 'using copper lines for gasoline'...
The US Coast Guard requires copper fuel lines on gasoline engines (see here), a google search revealed that copper tubing is used in the refining of gasoline (not as an active element or anything) and OEM lines are often copper lined or made from drawn copper.Nov 17, 2006
dang if it's good enough for them.... USE IT !!!
Jay
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 4:35pm
I had an old guy that sold 9N Fords new tell me not to use steel because of rust developing if the tractor sat with the tank empty. He recommended copper
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 5:23pm
We use copper on generator fuel lines and have for years. Not the same thing as we use diesel but that's what we use
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 7:55pm
Come back and tell us when it leaks due to the vibration.  Soft plumbers copper will often crack at the flare when use on something with vibration, like in automotive use. Most quality brake lines are a copper alloy that is plated on the outside to prevent rust and will bend easily as well as stand up to vibration.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 10:16pm
Use it.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 10:25pm
I agree with Paul 100%.  Plumbing copper is no good, I have never had any problems using 5/16 brake line for fuel on my tractors.  Use the tube benders and paint them up, they will look stock!
Gordy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 7:24am
I like to use the braided stainless covered lines for the old cars and tractors easy to use and looks good.
“If you can't explain it simply, you don't understand it well enough”
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 2:49pm
Gordy, where do you get your line from?  Where do you get the fittings from?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 4:13pm
Thanks!
             I have just gone to ebay ordered a kit like this.
         http://www.ebay.com/itm/Braided-PTFE-Hose-Line-Oil-Fuel-Feed-Return-Line-with-Seal-PTFE-Hose-Fittings/283165272105?_trkparms=aid%3D1110002%26algo%3DSPLICE.SOI%26ao%3D1%26asc%3D226207%26meid%3D2bbb956dd8d047c9a5c87b790b5440c6%26pid%3D100008%26rk%3D1%26rkt%3D12%26mehot%3Dpp%26sd%3D282754802499%26itm%3D283165272105%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DPromotedSellersOtherItemsV2&_trksid=p2047675.c100008.m2219
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 2:57am
buy extra copper line fer your still
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 12:35pm
For hand sanitizer and such???£
That’s a great idea Shamless.
This page was generated in 2.002 seconds.
