82s sickle mower questions
Dadscad3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dadscad3 Quote  Post ReplyReply Direct Link To This Post Topic: 82s sickle mower questions
    Posted: 02 Apr 2020 at 7:42am
I just bought a side mount sickle mower for my WD 45. it missing a few parts. Does anybody know how long and the size of the lift hydraulic ram i need? Im also missing the pulley attachment for the pto shaft that goes on back of the tractor, and missing the belt guard for the drive pulley set up on the back. I know very little about this set up and any help would be great! Thank you!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 7:54am
8" stroke and I think mine has a 1-1/2" or 2" diameter.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dadscad3 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 10:15pm
Thank you for the info!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 7:38pm
Make sure you get the right pulley for the PTO shaft. Dad had a MT John Deere with a belly mower. It had the wrong PTO pulley. It ran the sickle too slow. As a result I could only mow in low gear. Talk about booring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 8:11pm
I have a 82 S on my WD. I can get you some measurements tomorrow. I also my know of someone that may reproduce the rear shield for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 8:17pm
Which pulley? The one that slides onto the pto shaft of the tractor or the pulley attached to the pto shaft coming from the mower? Just so i am getting the correct measurements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 8:22pm
After I read your post again are you missing the entire drive assembly that attaches to the rear of the tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 6:57am
Pulley at mower pto shaft is 5-3/8"x1-1/8" wide.
Pto shaft pulley on tractor is 7"x-1-1/8" wide.
Belt is 7/8"x 52" if I remember correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 6:59am
Sorry for the double pic, and have no idea why it’s sideways
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 7:39am
What's the part numbers of them
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 10:57pm
parts #2 805127 sheave rear drive, #3 805128 spacer, #6 805126 hub rear drive sheave #8 512233 spring for lock pin, #9 pin, quick lock and the other sheave part #10 532034
 Part # 4 is used with a D19
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dadscad3 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 7:09am
I need the pulley set up that goes to the pto shaft of the tractor. That and the belt guard that covers the belt off of that pulley. Thank you for the pics and info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dadscad3 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 8:05am
This page was generated in 0.104 seconds.
