Big Ten starter bracket
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: Big Ten starter bracket
    Posted: 01 Apr 2020 at 1:21pm
I need the bracket for the starter/generator on a Big Ten to tension the belt.  Let me know if you've got any suggestions for a substitute if original isn't available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 6:10pm
I would think that Generator bracket should be the same bracket as for some of the other B series models. B110, 112, etc. I have a B110 and a Big 10. The Big 10 is in a million pieces but I probably could see if its the same bracket. What motor? Briggs?
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 3:14pm
It's a Briggs, but sticker on it says 12 HP.  Don't know if it's been replaced, but it looks like the pictures I've found online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 8:33am
Dwayne,
I looked at both the B110 and the Big 10. Both have Briggs, and both have the identical bracket for the starter/generator so I can confirm that for ya. Maybe you can find a bracket on e-bay. I usually find parts on there for my stuff....  HTH
Steve@B&B
