190 rattle in tourqe tube
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 190 rattle in tourqe tube
    Posted: 31 Mar 2020 at 9:31pm
I have a 190 that has a rattle in the tourqe tube only when the power director is in high does not do it in neutral or low and goes away after quarter throttle but very noticeable below that, any ieas?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 9:39pm
Been my experience you have a bearing going down or a tooth off a gear. Will result eventually  in break up of high range clutchs…  sorry for bummer reply...
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 10:08pm
No need to be sorry, with my luck I was expecting worse lol, you got me thinking maybe a broken gear tooth because when I shut the tractor off It caries the gra sound right to the end, if that makes any sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 7:59am
The reduction gear on torque tube shaft also wears splines out causing noise and brakes plates.       MACK
