Field Cultivator ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Field Cultivator ?
    Posted: 31 Mar 2020 at 5:54pm
There is a post on another forum asking about a D/A (1400) cultivator. He says it's 22' and his main tractor is 110 HP. Several thought this would be a "load" for  the tractor. Just how deep is a f/c run ? I've never been around one so am curious. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 6:01pm
Not much more than 6-8", IIRR...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 6:16pm
WOW, that's how deep we pull a chisel plow,7-8 inches. I thought perhaps a f/c was only 3-4 inches LOL!!  Like I said, have no experience with them.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 6:34pm
I know one guy that pulls 34 foot with a 4020!---YA!---BUT you can stand in front of it and see the sun shining off the sweeps when they are in the ground!---a waste of time!--I always tried to go at least 4" with my 48 foot brady 6" is better but not really needed.
Ole 440 walked the dog with it. --- guy across the road always stared at me, course he ran green paint and never did like my orange stuff to be in the neighborhood! LOL!!
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 7:27pm
Field cultivators work best at 6-7 mph.  Run usually 3-6 inches deep depends on what you are trying to accomplish.  6-7 mph takes horsepower to run at those depths. Also depends what soils you have.  Sandy loam-pulls easy Clay loam-pulls hard
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 7:38pm
Are there any comparisons between a f/c and a true disc ? Seems like stones/rocks would tear the SH*T out of a f/c at 5+ mph Ouch
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 8:16pm
I guess we just run deep enough to take out tractor tracks, basically just trying to smooth out seed bed.
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 8:32pm
Guys who say they run a field cultivator or soil finisher 6 inches deep also think they chisel 16 to 18 inches deep with an old glencoe chisel. Malarkey! 3 inches is plenty deep. Get out and actually measure your depth guys
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 8:48pm
If you can get it in 6" deep front and back, you'll need something with tracks to pull it + at 6" deep it will plug with trash in a clean field.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 8:57pm
Agree 3in is plenty...at least for a finish pass. if you're trying to level chiseled ground you might want it deeper but I just run it the same . the second pass runs a little deeper on its own. 3in of fluff is more than enough unless you have old Allis planter. Seems to me that a F/C and disc pull comparatively for same size. Of course it would all depend on depth wouldn't it?
Another thing to consider....5 inch sweeps pull easier than 9 inch so you could conceivably pull a 22ft F/C with narrow sweeps with 110hp if you didn't bury it.
Edited by SteveM C/IL - 31 Mar 2020 at 9:03pm
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 10:19pm
If you try to pull a field cultivator either too fast or too deep they will begin to bounce then you either have to slow down or raise them up just a bit. The other thing would be if he is pulling it with say a 8010 front wheel assist he would probably do ok most of the time
Edited by DanWi - 31 Mar 2020 at 10:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 4:46am
I was a little deep, on that estimate, but around here we are mostly sandy soils.  Heard of some neighbors agruin about chisel plowin 12-16" deep!Wink
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 12:43pm
I have pulled a 40' wil rich field cultivator with a case IH 8910 that's a 140 hp 2wd tractor it's just deep enough for the leveling finger mounted to the back to scratch the ground. So maybe 2 " deep. It's no problem if the grounds not wet. I can pull the same emplement behind a JD 8430 140 hp articulating tractor with a 60' harrow behind it usually 4" deep and not know its back there. If you go deeper than 3 to 4" with your field cultivator your wearing out the shank instead of the shovel. We go thru a lot of shovels every year.
Edited by Dakota Dave - 01 Apr 2020 at 12:46pm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 2:25pm
Dad pulled a 21' IH with a 1066 in good Iowa dirt.  3-4" would be about as deep as you need.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 5:38pm
Thanks guys, for some reason I was always under the impression that a f/c was designed to "tickle" the ground Smile.  Have a safe planting season guys Wink
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 5:44pm
2 to 3 inches for me just to smooth out the field and incorporate a fertilizer spread and or pre-emerge herbicide. But Allis did advertise the 1400 as a Chiselvator and as either a primary tillage tool or secondary. I think you'll eventually bend shanks or wear them out if you tried to use it as primary in my ground.
Edited by Lonn - 01 Apr 2020 at 5:47pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 5:57pm
That was my thoughts, the shanks (in pictures that I've since looked up) don't look very heavily built at all Sleepy. Our old school BURCH row crop cultivator (hasn't been used in 20 years) has heavier shanks than some of the 'vator's I've seen.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 8:32pm
3 inches is about right. Pulled a 18 foot Brady with a 7000 you wouldn’t want anymore. Pulled a 24 foot CIH with the 8030 it took some power. Size of the sweeps plays into it also. Spikes would pull pretty easy. Doubt a person would do much with a 22 foot on 110 hp. Rayl on Agtalk will tell you he pulls a 50 foot with his 4020.
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 10:01am
We pull a 28 foot behind our tractor (green one) at 7 mph but all we are doing is leveling the field from ripping.  The bean stubble we just take out the stubble and level it.  Basically we have the top of the second bolt head exposed.
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 10:18am
The 1400 is twice as heavy as a 1200, 1300, or 1350 cultivator. With a 110 hp tractor you could easily pull these but would need 50 hp more to pull a 1400 cultivator. I have one of each of these. 1400 is more of a primary cultivator tool, not so good for finish use. Just my opinion.
