7000 BB pto/hyd issue
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 BB pto/hyd issue
    Posted: 28 Mar 2020 at 9:20am
I have a 7000 BB I tedd hay with. When you pull a remote lever or power shift gears. With the pto on The pto lever will fall to the rear and shut off. Im assuming it's a hyd. Pressure issue but Wasn't sure where to start. Any help is appreciated.
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 6:49pm
Mine does the same from time to time when warmed up. It was much worse before I resealed the power shift clutches. I was told you can shorten the spring in the PTO valve spool a turn or two to help the issue as well. I just take an empty water bottle and wedge it between the PTO lever and the height adjustment lever. Works like a charm. I think if I resealed the PTO clutch pack it may eliminate the problem, but I don’t have any issues with it so hate to tear it apart. My other hypothesis is the pump is just a little worn. I don’t recall mine being affected by the remotes. That sounds like you may have a sticking priority valve in the pump?
Hurst
1979 Allis Chalmers 7000
5800 Hours
